Errors with MrSID gdalplugin for ms4w1.0.1
Ivan Kautter
ivankautter at HOTMAIL.COM
Tue Sep 6 00:31:42 EDT 2005
List serve subscribers,
First, please excuse posting this to multiple lists. In attempting to use
the MrSID gdalplugin, I am receiving these errors:
Warning: [MapServer Error]: msDrawMap(): Failed to draw layer named
'100K_DRGs'. in C:\ms4w\apps\maplab-2.2\htdocs\mapedit\preview.php on line
469
Warning: [MapServer Error]: msDrawRaster(): Unrecognized or unsupported
image format in C:\ms4w\apps\maplab-2.2\htdocs\mapedit\preview.php on line
469
Warning: [MapServer Error]: drawEPP(): EPPL7 support is not available. in
C:\ms4w\apps\maplab-2.2\htdocs\mapedit\preview.php on line 469
Warning: [MapServer Error]: msInsertHashTable: Invalid hash table or key in
..........same error for multiple lines
Fatal error: Call to a member function on a non-object in
C:\ms4w\apps\maplab-2.2\htdocs\mapedit\preview.php on line 474
To specify the environment in which I am attempting to use the plugin , it
is being run under ms4w 1.0.1, maplab2.2, phpmapscript4.4, Windows XP home.
MrSID files are being accessed from a shapefile that is acting as a
tileindex for 45 DRG Topos for state of California. Image Path in the
shapefile is defined relative to position of the map file.
http.conf has been altered to include these lines:
SetEnv GDAL_DATA "/ms4w/gdaldata"
#SetEnv GDAL_DATA "/ms4w/tools/ogr-utils"
SetEnv GDAL_DRIVER_PATH "/ms4w"
Required plugin dll and LizardTech dll are in the correct locations.
The second error is confusing in that it says an unsupported format, but my
impression was that the plugin was intended to circumvent re-building the
gdal dlls to support MrSID, so if the plugin were performing its function
such an error should not be possible. Perhaps I am mistaken.
It seems there could be any number of problems here, but I am hoping someone
has some experience using this plugin that may have some suggestion for me.
Thanks for your time and efforts.
Ivan Kautter
