[postgis-users] Problem with 'using unique' in Mapserver DATA
statement
Bill Binko
bill at BINKO.NET
Thu Sep 8 01:33:33 EDT 2005
I reported this recently: it's Bug #1443 in the Mapserver bugzilla
database.
Per Frank's suggestion, I have backed out the mappostgis.c version to a
July version. However, there is a workaround.
The change that was put in place (that introduced the bug) is a default
that sets the UNIQUE parameter to oid if it's not set. So, you can change
your DATA statement to this and get around it:
DATA "geom from (select geom, gid as oid, pearseda from pda42304) as foo
using SRID=42304"
That will alias gid to 'oid' and the default will make it work.
Yes: this is a huge hack, and it's a bug (hence my report). However, it
might get you working.
Bill
On Wed, 7 Sep 2005, Debbie Pagurek wrote:
> strk at refractions.net wrote:
> >On Wed, Sep 07, 2005 at 12:25:57PM -0400, Debbie Pagurek wrote:
> >>I seem to have a problem using UNIQUE indexes in my MapServer Data
> >>statements.
> >>This doesn't work:
> >>DATA "geom from (select geom, oid,gid, pearseda from pda42304) as foo
> >>using unique gid using SRID=42304"
> >Did you try swapping "using unique gid" and "using SRID=42304" ?
> >(the mapserver connector is pretty dumb)
> >--strk;
> >_______________________________________________
> >postgis-users mailing list
> >postgis-users at postgis.refractions.net
> >http://postgis.refractions.net/mailman/listinfo/postgis-users
> I just realized that it's the version of MapServer I'm using. I'm using
> the windows binary version 4.7. When I tried with the 4.6 windows
> binary, it worked fine. Argh.
> I'll let the mapserver people know.
> Debbie Pagurek
> __________________________________________________
> Do You Yahoo!?
> Tired of spam? Yahoo! Mail has the best spam protection around
> http://mail.yahoo.com
