Raster projection shift
Alessandro Pasotti
ale.pas at TISCALI.IT
Thu Sep 8 12:54:07 EDT 2005
Hello,
I have a problem with a raster file ETM+, it is a GeoTIFF format, there is a
shift (about 50m) with my shapefiles (ported to postgis), please see the
attached image.
postgis srid is 26591
gdalinfo says:
-------8<------------------------------------
gdalinfo ETMPLUS.tif
Driver: GTiff/GeoTIFF
Size is 17868, 15764
Coordinate System is:
PROJCS["WGS 84 / UTM zone 32N",
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.2572235629972,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",9],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AUTHORITY["EPSG","32632"]]
Origin = (449380.875000,5051290.125000)
Pixel Size = (14.25000000,-14.25000000)
Metadata:
TIFFTAG_XRESOLUTION=72
TIFFTAG_YRESOLUTION=72
TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
Corner Coordinates:
Upper Left ( 449380.875, 5051290.125)
Lower Left ( 449380.875, 4826653.125)
Upper Right ( 703999.875, 5051290.125)
Lower Right ( 703999.875, 4826653.125)
Center ( 576690.375, 4938971.625)
Band 1 Block=17868x1 Type=Byte, ColorInterp=Gray
Extract from the mapfile:
# Raster layer
LAYER
NAME "etmplus"
GROUP "Sfondo"
DATA "ETMPLUS.tif"
TYPE RASTER
OFFSITE 0 0 0
STATUS OFF
METADATA
"wms_srs" "EPSG:32632"
"wms_name" "etmplus"
"wms_group" "Sfondo"
"wms_server_version" "1.1.1"
"wms_format" "image/jpeg"
"typelabel" "etmplus"
END
PROJECTION
"init=epsg:32632"
END
END
# Start of layer - [Comuni]
LAYER
NAME "comuni"
GROUP Cartografia
STATUS ON
DEBUG ON
DATA "the_geom from comuni"
CONNECTIONTYPE postgis
CONNECTION "user=--- dbname=--- host=localhost password=---"
TYPE POLYGON
UNITS METERS
DUMP TRUE
METADATA
"wms_title" "Comuni"
"wms_srs" "EPSG:26591"
"wfs_title" "Comuni"
END
TOLERANCE 3
LABELITEM "nome"
CLASS
TEMPLATE 'ttt'
NAME "Comune"
SYMBOL "circle"
SIZE 3
OUTLINECOLOR 200 0 0
LABEL
TYPE TRUETYPE
FONT "fritqat"
SIZE 10
BACKGROUNDCOLOR 255 255 255
BACKGROUNDSHADOWCOLOR 112 112 112
MINSIZE 4
MAXSIZE 256
POSITION AUTO
OFFSET 0 0
ANGLE AUTO
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 0 0 0
OUTLINECOLOR 255 255 255
ANTIALIAS TRUE
PARTIALS FALSE
FORCE FALSE
END
# End of Label
END
# End of Class
END
# End of Layer comuni
I really don't know where to find a solution.
Thanks for any help.
Alessandro Pasotti
itOpen - "Open Solutions for the Net Age"
w3: www.itopen.it
ICQ: 245871392
Linux User# 167502
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050908/bbe01443/mapserv-shift.png
