Raster projection shift
Frank Warmerdam fwarmerdam at GMAIL.COM
Thu Sep 8 13:08:26 EDT 2005
On 9/8/05, Alessandro Pasotti <ale.pas at tiscali.it> wrote:
> Hello,
> I have a problem with a raster file ETM+, it is a GeoTIFF format, there is a
> shift (about 50m) with my shapefiles (ported to postgis), please see the
> attached image.
> postgis srid is 26591
Alessandro,
PROJ.4 does not "know" what datum shift to use for the Monte
Mario datum underlying EPSG:26591.  You will need to research
appropriate towgs84 value to use and apply them in the epsg
lookup file.
This offset is almost certain related to datum shifting (or a lack
thereof).
Best regards,
