Raster projection shift
Armin Burger
armin.burger at GMX.NET
Thu Sep 8 14:13:49 EDT 2005
Alessandro,
you could try the parameter +towgs84=-225,-65,9,0,0,0,0 for the
projection definition of the Gauss-Boaga/Monte Mario data to force a
datum shift (taken from
http://dbwww.essc.psu.edu/lasdoc/overview/geomreg/dtm_list.html, "Datum
: (210) ROME 1940") and see if the data match better then.
Armin
Alessandro Pasotti wrote:
> Hello,
> I have a problem with a raster file ETM+, it is a GeoTIFF format, there is a
> shift (about 50m) with my shapefiles (ported to postgis), please see the
> attached image.
> postgis srid is 26591
> gdalinfo says:
> -------8<------------------------------------
> gdalinfo ETMPLUS.tif
> Driver: GTiff/GeoTIFF
> Size is 17868, 15764
> Coordinate System is:
> PROJCS["WGS 84 / UTM zone 32N",
> GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.2572235629972,
> AUTHORITY["EPSG","7030"]],
> AUTHORITY["EPSG","6326"]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433],
> AUTHORITY["EPSG","4326"]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",9],
> PARAMETER["scale_factor",0.9996],
> PARAMETER["false_easting",500000],
> PARAMETER["false_northing",0],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> AUTHORITY["EPSG","32632"]]
> Origin = (449380.875000,5051290.125000)
> Pixel Size = (14.25000000,-14.25000000)
> Metadata:
> TIFFTAG_XRESOLUTION=72
> TIFFTAG_YRESOLUTION=72
> TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
> Corner Coordinates:
> Upper Left ( 449380.875, 5051290.125)
> Lower Left ( 449380.875, 4826653.125)
> Upper Right ( 703999.875, 5051290.125)
> Lower Right ( 703999.875, 4826653.125)
> Center ( 576690.375, 4938971.625)
> Band 1 Block=17868x1 Type=Byte, ColorInterp=Gray
> Extract from the mapfile:
> # Raster layer
> LAYER
> NAME "etmplus"
> GROUP "Sfondo"
> DATA "ETMPLUS.tif"
> TYPE RASTER
> OFFSITE 0 0 0
> STATUS OFF
> METADATA
> "wms_srs" "EPSG:32632"
> "wms_name" "etmplus"
> "wms_group" "Sfondo"
> "wms_server_version" "1.1.1"
> "wms_format" "image/jpeg"
> "typelabel" "etmplus"
> END
> PROJECTION
> "init=epsg:32632"
> END
> END
> # Start of layer - [Comuni]
> LAYER
> NAME "comuni"
> GROUP Cartografia
> STATUS ON
> DEBUG ON
> DATA "the_geom from comuni"
> CONNECTIONTYPE postgis
> CONNECTION "user=--- dbname=--- host=localhost password=---"
> TYPE POLYGON
> UNITS METERS
> DUMP TRUE
> METADATA
> "wms_title" "Comuni"
> "wms_srs" "EPSG:26591"
> "wfs_title" "Comuni"
> END
> TOLERANCE 3
> LABELITEM "nome"
> CLASS
> TEMPLATE 'ttt'
> NAME "Comune"
> SYMBOL "circle"
> SIZE 3
> OUTLINECOLOR 200 0 0
> LABEL
> TYPE TRUETYPE
> FONT "fritqat"
> SIZE 10
> BACKGROUNDCOLOR 255 255 255
> BACKGROUNDSHADOWCOLOR 112 112 112
> MINSIZE 4
> MAXSIZE 256
> POSITION AUTO
> OFFSET 0 0
> ANGLE AUTO
> BUFFER 0
> MINDISTANCE -1
> MINFEATURESIZE -1
> COLOR 0 0 0
> OUTLINECOLOR 255 255 255
> ANTIALIAS TRUE
> PARTIALS FALSE
> FORCE FALSE
> END
> # End of Label
> END
> # End of Class
> END
> # End of Layer comuni
> I really don't know where to find a solution.
> Thanks for any help.
> Alessandro Pasotti
> itOpen - "Open Solutions for the Net Age"
> w3: www.itopen.it
> ICQ: 245871392
> Linux User# 167502
