MySQL access and joins
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Thu Sep 8 15:02:07 EDT 2005
> > Will simple MySQL tables work as the join table? I believe
> > --with-mygis will work on a non-sppatial DB
> Yes, but this will work ONLY for template based queries (this
> is not a mygis
> limitiation per se, MapServer has separate code for the template (or
> mapscript) queries, and join functionality you might wish to
> use in a .MAP
> file).
Thanks for the info. What do you mean by template based queries? My
overall goal is to generate a map (with shp2img) whose mapfile defines a
layer which has a join btw a shapefile and MySQL table, and CLASS items
based on expressions in columns in the MySQL table.
Thanks for any advice and / or recommendation.
..Tom
