SLD PIXMAP Error With How-To Example
Jennifer Zeisloft
jzeisloft at GMAIL.COM
Thu Sep 8 16:01:58 EDT 2005
Hello All-
I am starting to play with SLD and am attempting to use an external graphic
to symbolize a point. I first tried it with my own external graphic, but got
the error message:
*Warning*: [MapServer Error]: loadSymbol(): Symbol of type PIXMAP has no
image data. in *C:\ms4w\apps\chameleon\htdocs\common\wrapper\map_session.php
* on line *215*
*Warning*: Failed to open map file /ms4w/tmp/sess_4320970788d61/1126209374-
4254.map in *C:\ms4w\apps\chameleon\htdocs\common\wrapper\map_session.php*on
line
*215*
*Fatal error*: Call to a member function on a non-object in *
C:\ms4w\apps\chameleon\htdocs\widgets\KeyMapDHTML\KeyMapDHTML.widget.php* on
line *150*
I then tried it with the sld_symbols_external.xml file from the SLD How-To
document (I changed the layer name, of course) and received the same error.
I also tried using PNG instead of GIF - same error. Can anyone offer a hint?
Thanks in advance for your help!
Jennifer Zeisloft
UW Sea Grant
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050908/c5c52b88/attachment.html
