SLD PIXMAP Error With How-To Example
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Thu Sep 8 16:33:35 EDT 2005
Not sure what the initial error is but you could check the map file
1126209374-4254.map and see if the inline symbols created reference an
existing png or gif file.
I would also be nice if you could provide a quick was (+ all realted
files) to reproduce this bug. At this point I am not sure how to
reproduce it.
Later,
Jennifer Zeisloft wrote:
> Hello All-
> I am starting to play with SLD and am attempting to use an external
> graphic to symbolize a point. I first tried it with my own external
> graphic, but got the error message:
> *Warning*: [MapServer Error]: loadSymbol(): Symbol of type PIXMAP has no
> image data. in
> *C:\ms4w\apps\chameleon\htdocs\common\wrapper\map_session.php* on line *215*
> *Warning*: Failed to open map file
> /ms4w/tmp/sess_4320970788d61/1126209374-4254.map in
> *Fatal error*: Call to a member function on a non-object in
> *C:\ms4w\apps\chameleon\htdocs\widgets\KeyMapDHTML\KeyMapDHTML.widget.php*
> on line *150*
> I then tried it with the sld_symbols_external.xml file from the SLD
> How-To document (I changed the layer name, of course) and received the
> same error. I also tried using PNG instead of GIF - same error. Can
> anyone offer a hint? Thanks in advance for your help!
> Jennifer Zeisloft
> UW Sea Grant
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
