STATUS in LAYER object
Fawcett, David
David.Fawcett at STATE.MN.US
Thu Sep 8 17:26:57 EDT 2005
To have a layer visible when STATUS is set to ON, you also need to pass the name of the layer in the URL e.g. '&layer=relief'
David.
David Fawcett
Minnesota Office of Environmental Assistance
david.fawcett at moea.state.mn.us
651.215.0200
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of Gregory Yetman
Sent: Thursday, September 08, 2005 4:11 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] STATUS in LAYER object
I'm new to both mapserver and the list, hopefully this question isn't
too 'newbie'.
I have a map file that works fine:
MAP
IMAGETYPE JPEG
EXTENT -180 -90 180 0
SIZE 320 320
SHAPEPATH "data"
PROJECTION
"proj=latlong"
"ellps=WGS84"
END
LAYER # sample jpeg LDEO layer
NAME relief
STATUS DEFAULT
TYPE RASTER
TileIndex 'i_512/i_512.shp'
TileItem "Location"
PROJECTION
"proj=merc"
"ellps=WGS84"
END
END # Raster layer ends here
END # end of map file
However, if I change STATUS from DEFAULT to ON the layer does not
appear, the image produced is empty. According to the manual (definition
below), ON is what should be used in 'normal use'. So is something wrong
with my map file or is there an issue with the use of STATUS?
Thanks,
Greg
STATUS [on|off|default]
Sets the current status of the layer. Often modified by MapServer
itself. Default turns the layer on permanently.
Some notes regarding the STATUS values:
In CGI mode, layers with STATUS DEFAULT cannot be turned off
using normal mechanisms. It is recommended to set layers to
STATUS DEFAULT while debugging a problem, but set them back to
ON/OFF in normal use.
For WMS, layers in the server mapfile with STATUS DEFAULT are
always sent to the client.
Gregory Yetman
Center for International Earth Science Information Network (CIESIN)
Columbia University
URL: http://www.ciesin.columbia.edu/
e-mail: gyetman (at) ciesin.columbia.edu
tel: (845) 365-8982
