DGN text rotation
Sylvain Beorchia sbeorchia at GI-LEMANS.COM
Fri Sep 9 03:35:37 EDT 2005
Hi list,
We found the solution. You just need to add an entry  "default   arial.ttf"
in the font.txt file and copy the arial.ttf file in the font directory of
your application...and it works...great!!
Sylvain Beorchia.
----- Original Message -----
From: "Sylvain Beorchia" <sbeorchia at GI-LEMANS.COM>
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Thursday, September 08, 2005 11:05 AM
Subject: [UMN_MAPSERVER-USERS] DGN text rotation
hi list,
i am using mapserver and ogr (dgnlig) to display microstation dgn file.
display of dgn file is ok except the text rotation. all text have a 0°
rotation.
here is a piece of my map file :
LAYER
NAME dgn
TYPE ANNOTATION
STATUS DEFAULT
CONNECTIONTYPE OGR
CONNECTION "test.dgn"
STYLEITEM "AUTO"
CLASS
END
END
i've used ogrinfo to check that dgnlib give the correct angle, it 's ok
is it possible to display dgn text with the correct rotation ?
if then can u give me a map file example ?
as u can see in the layer definition , i use "STYLEITEM AUTO", could it be
the problem ?
Thanls
