STATUS in LAYER object
Gregory Yetman gyetman at CIESIN.COLUMBIA.EDU
Fri Sep 9 09:05:46 EDT 2005
Thanks to David Fawcett pointed out my problem -- that I needed to pass
the layer name in as part of the URL.
Rather than changing the flag, I think that perhaps the documentation
just needs some additional info. It's not obvious from the definition of
STATUS when you should use ON vs. DEFAULT.
Greg
Gerry Creager wrote:
> Following on the heels of this note, might we consider a change to the
> STATUS flag in layers, changing 'ON' to something else, such as
> 'SELECTABLE'?
> Gerry
> Gregory Yetman wrote:
>> Hi,
>> I'm new to both mapserver and the list, hopefully this question isn't
>> too 'newbie'.
>> I have a map file that works fine:
>> MAP
>>  IMAGETYPE      JPEG
>>  EXTENT        -180 -90 180 0
>>  SIZE           320 320
>>  SHAPEPATH      "data"
>>  PROJECTION
>>    "proj=latlong"
>>    "ellps=WGS84"
>>  END
>>  LAYER # sample jpeg LDEO layer
>>      NAME         relief
>>      STATUS       DEFAULT
>>      TYPE         RASTER
>>      TileIndex    'i_512/i_512.shp'
>>      TileItem "Location"
>>      PROJECTION
>>          "proj=merc"
>>          "ellps=WGS84"
>>       END
>>   END # Raster layer ends here
>> END # end of map file
>> However, if I change STATUS from DEFAULT to ON the layer does not
>> appear, the image produced is empty. According to the manual (definition
>> below), ON is what should be used in 'normal use'. So is something wrong
>> with my map file or is there an issue with the use of STATUS?
>> Thanks,
>> Greg
>> STATUS [on|off|default]
>>    Sets the current status of the layer. Often modified by MapServer
>>    itself. Default turns the layer on permanently.
>>    Some notes regarding the STATUS values:
>>          In CGI mode, layers with STATUS DEFAULT cannot be turned off
>>          using normal mechanisms. It is recommended to set layers to
>>          STATUS DEFAULT while debugging a problem, but set them back to
>>          ON/OFF in normal use.
>>          For WMS, layers in the server mapfile with STATUS DEFAULT are
>>          always sent to the client.
>> Gregory Yetman
>> Center for International Earth Science Information Network (CIESIN)
>> Columbia University
>> URL: http://www.ciesin.columbia.edu/
>> e-mail: gyetman (at) ciesin.columbia.edu
>> tel: (845) 365-8982
Gregory Yetman
Columbia University
tel: (845) 365-8982
