OGR virtual spatial data
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Fri Sep 9 09:21:14 EDT 2005
> On 9/7/05, Kralidis,Tom [Burlington] <Tom.Kralidis at ec.gc.ca> wrote:
> > Hi,
> > I have a MySQL table which I'm connecting to via OGR's
> virtual spatial
> > data option and unixODBC. The table has ~ 2 million records with x
> > and y columns. I have setup an .ovf and mapfile accordingly.
> > When I run shp2img, CPU usage spikes up to 100% and then a
> core dump
> > results. I am running shp2img with an extent which will
> result in far
> > less records.
> Tom,
> As Bart notes, new versions of GDAL should handle the spatial
> queries much more efficiently for ODBC via VRT (assuming the
> database can handle the query efficiently).
> I am concerned about the crash though. There was a cleanup
> issue with an older version of the OGR VRT driver that might
> be causing it. If the problem persists with GDAL 1.3.0 let
> me know and we can try to dig into it.
When upgrading to 1.3.0, there were no crash or cleanup issues (I used
VRT with a MySQL connection).
Thanks
..Tom
