Perl Mapscript Problem
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Tue Sep 13 21:09:41 EDT 2005
Hi All,
I had dynamic symbol manipulation working on MS 4.01 but can not get it
to work on 4.4.1 or 4.6.1. In the following code snippets every think
works with the default symbol that is defined in symbolset file, but the
code does not let me change the imagepath on the fly.
Also, I can not get the label on the umarker layer to show unless I
specify LABELCACHE FALSE and umarker layer is the last in the
mapfile.
Any ideas or help would be appreciated.
-Steve W.
From the mapscript:
my $lay = $mapObj->getLayerByName('umarker');
if ($lay) {
$lay->{status} = 1;
my $class = $lay->getClass(0);
my $pnt = new mapscript::pointObj();
my @marks = split(/;/, $mark);
foreach my $x (@marks) {
my ($y, $x, $txt, $sym) = split(/[\s,]/, $x);
if ($sym && -r "$symbol_path/$sym") {
my $style = $class->getStyle(0);
$style->{symbolname} = "$symbol_path/$sym";
$pnt->{x} = $x;
$pnt->{y} = $y;
$pnt->draw($mapObj, $lay, $imgObj, 0, $txt);
Or alternately from mapscript:
if ($lay) {
$lay->{status} = 1;
my $symbolset = $mapObj->{symbolset};
my $symbol = $symbolset->getSymbolByName('marker');
$symbol->{imagepath} = "$symbol_path/$sym";
$pnt->{x} = $x;
$pnt->{y} = $y;
From the mapfile:
LAYER
NAME "umarker"
STATUS ON
TYPE POINT
LABELCACHE FALSE
TEMPLATE "ttt.html"
CLASS
NAME "User Marker"
#TEXT "HERE"
SYMBOL "marker"
COLOR 0 0 0
LABEL
TYPE TRUETYPE
FONT "arial-bold"
SIZE 8
POSITION AUTO
OFFSET 0 0
BUFFER 4
COLOR 0 0 0
OUTLINECOLOR 230 230 230
FORCE TRUE
END
END
END
From the symbol.sym symbolset file:
Symbol
Name 'marker'
Type PIXMAP
Image 'markers/purppin.png'
Transparent 1
END
