Units problem
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Wed Sep 14 12:57:35 EDT 2005
Hi There,
Normally the unit should be parsed from the filter and set as the
value of the toleranceunits and your distance should be used to update
the tolerance of the layer.
The only thing that might be missing (assuming that all filter
encoding is parsed properly) is that you should set the units of your
map file to degrees (at the map level set UNITS "dd"). If that does
not solve your issue please sned me a simple map file/data/and the
filter encoding and I will test it here.
Later,
Miguel Gonçalves wrote:
> Hello list,
> I am using mapserver 4.6 for windows
> I am using the following DWidth request
> http://localhost/cgi-bin/mapserv.exe?VERSION=1.0.0&SERVICE=WFS&REQUEST=GetFeature&TYPENAME=cities&MAP=../MAPS/tutorial/europe_1.map&Filter=
> <Filter>
> <DWithin>
> <PropertyName>Geometry</PropertyName>
> <gml:Point>
> <gml:coordinates>-8.418000,41.539600</gml:coordinates>
> </gml:Point>
> <Distance units='m'>1000</Distance>
> </DWithin>
> </Filter>
> and I am having some problems with the units.
> I specified units='m' but, in the results that I obtain, the distance
> between the geographical features is in degrees (I checked with ArcMap).
> Can you help me to solve this problem?
> Thanks.
> Best regards.
> Miguel
> P.S. If it helps, here is my map object
> MAP
> EXTENT -36.133725 5.7104918367 66.0633 71.1839
> SHAPEPATH "europe_1_data"
> WEB
> METADATA
> WFS_TITLE "Mapa da Europa"
> WFS_SRS "http://localhost/cgi-bin/mapserv.exe?"
> END
> END
> ############## LAYER cities
> LAYER
> NAME cities
> DATA cities
> TYPE line
> DUMP TRUE TOLERANCEUNITS METERS
> METADATA
> WFS_TITLE "cities layer"
> GML_INCLUDE_ITEMS "all"
> END
> END
> ############## LAYER mjroads
> LAYER
> NAME mjroads
> DATA mjroads
> TYPE line
> DUMP TRUE
> METADATA
> WFS_TITLE "mjroads layer"
> END
> END
> ##############LAYER country
> LAYER
> NAME countries
> DATA countries
> TYPE polygon
> DUMP TRUE
> METADATA
> WFS_TITLE "country layer"
> END
> END
> END
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
