DBF to Shape OGR JOIN, PHP crashes
Christopher R. Thorne
christhorne at SYMPATICO.CA
Thu Sep 15 08:18:08 EDT 2005
What do you mean an "OGR style index"? This maybe my problem. ;)
Chris
Frank Warmerdam wrote:
> On 9/14/05, Christopher R. Thorne <christhorne at sympatico.ca> wrote:
>>Hello list,
>>I am trying to solve an OGR Connection to JOIN a shape file to a DBF
>>problem. I cannot figure out weather it is my layer definition or
>>something else.
>>I HAVE been able to get a join work with a different data set, but it
>>seems there are some problems with the layer(data) I wish to display.
>>Every time I try the Join. My CPU goes to %100 do to PHP.exe failing to
>>close. I have to reboot my windows machine.
>>Other than size of data set (meaning bigger) I cannot see any difference
>>with my layer definition.
> Chris,
> Does the .dbf file have an OGR style index on the the BBL field? If
> not, the join will be exceedingly slow for any non-trivial dataset.
> Have you tried the join from the ogrinfo commandline to isolate it from
> MapServer related issues? If you think you have proper attribute
> indexes, and if things are still slow you can package up an example
> I can test with ogrinfo and I will look at it.
> Best regards,
Christopher R. Thorne, GIS Specialist
Tel:(613)523-6593, Ottawa ON Canada
