Perl Mapscript Problem
Sean Gillies
sgillies at FRII.COM
Thu Sep 15 11:02:28 EDT 2005
On Sep 13, 2005, at 7:09 PM, Stephen Woodbridge wrote:
> Hi All,
> I had dynamic symbol manipulation working on MS 4.01 but can not get it
> to work on 4.4.1 or 4.6.1. In the following code snippets every think
> works with the default symbol that is defined in symbolset file, but
> the
> code does not let me change the imagepath on the fly.
> Also, I can not get the label on the umarker layer to show unless I
> specify LABELCACHE FALSE and umarker layer is the last in the
> mapfile.
> Any ideas or help would be appreciated.
> -Steve W.
Steve,
Perhaps mutating the imagepath has no effect due to caching of symbol
images. About the labelcache, I would guess that the label is losing
the battle against other in the map.
This is how I do dynamic symbols
# create a new symbol
new_symbol = mapscript.symbolObj('symbol_a',
'/path/to/symbol_a.png')
# add a *copy* of the symbol to the map symbolset and get the index
new_symbol_index = map.symbolset.appendSymbol(new_symbol)
See http://zcologia.com/mapserver/mapscript#symbolobj and
http://zcologia.com/mapserver/mapscript#symbolsetobj or the same docs
on the new mapserver site.
The symbolObj also has a method to set symbol imagery directly. See
http://zcologia.com/mapserver/imagery-howto#images-and-symbols.
Sean
Sean Gillies
sgillies at frii dot com
http://zcologia.com
