OGR DBF JOINS, Numeric Values now String
Christopher R. Thorne
christhorne at SYMPATICO.CA
Thu Sep 15 11:15:50 EDT 2005
Hello again,
I got a OGR Join to work between a Shapefile and DBF. The DBF has much
fewer records than what is found in the shapefile. The problem that I am
having is that the CLASSITEM I wish to classify on the JOINED attribute
which in the dbf is a numeric value with two decimal points. eg. 0.00
All Shapefile features that DO NOT have a successful JOIN contain a
value 'blank'. ie. EXPRESSION "" This of course is not valid for numeric
item 'blank' should be 0.00
Which leads into my next observation numerical values that are joined
seem to be considered string values vs. numerical.
For example
1) DOES NOT WORK
EXPRESSION "10"
DOES WORK
EXPRESSION "10.00" does
1) DOES NOT WORK
EXPRESSION ([test2.FARGAP] eq 20.00)
2) DOES WORK
EXPRESSION ('[test2.FARGAP]' eq '20.00')
Is this a limitation of a DBF OGR JOIN ie. importing all values as
string, or is there something wrong with my DBF (ie. not created
properly, defective), or am I missing something in my JOIN CONNECTION?
CONNECTIONTYPE OGR
DATA "SELECT test2.FARGAP FROM MN_BBL LEFT JOIN
'D:/maps/data/archived/nyc/nyc/dbf_joins/test2.dbf'.test2 ON
MN_BBL.BBL=test2.BBL"
CONNECTION "D:/maps/data/archived/nyc/nyc/dbf_joins/MN_BBL.shp"
CLASSITEM "test2.FARGAP"
Thanks again,
Chris
Christopher R. Thorne, GIS Specialist
christhorne at sympatico.ca
Tel:(613)523-6593, Ottawa ON Canada
