Units problem
Miguel Gonçalves mgoncalves at DSI.UMINHO.PT
Fri Sep 16 05:29:39 EDT 2005
Hi Yewondwossen,
I already sent you the files for your personal mail.
Tell me if you have problems receiving it.
Best regards.
Miguel
Miguel Gonçalves wrote:
> Hi Yewondwossen,
> I tried what you said but stills not worling.
> Can I send the data files and the map object to your personal mail?
Yes, please send it to me.
Later,
Thanks.
Best regards.
Miguel
Yewondwossen Assefa wrote:
> Hi There,
>  Normally the unit should be parsed from the filter and set as the
> value of the toleranceunits and your distance should be used to update
> the tolerance of the layer.
>  The only thing that might be missing (assuming that all filter
> encoding is parsed properly) is that you should set the units of your
> map file to  degrees (at the map level set UNITS "dd").  If that does
> not solve your issue please sned me a simple map file/data/and the
> filter encoding and I will test it here.
> Later,
>> Hello list,
>> I am using mapserver 4.6 for windows
>> I am using the following  DWidth request
>> http://localhost/cgi-bin/mapserv.exe?VERSION=1.0.0&SERVICE=WFS&REQUEST=GetFeature&TYPENAME=cities&MAP=../MAPS/tutorial/europe_1.map&Filter=
>> <Filter>
>>    <DWithin>
>>        <PropertyName>Geometry</PropertyName>
>>        <gml:Point>
>>            <gml:coordinates>-8.418000,41.539600</gml:coordinates>
>>        </gml:Point>
>>        <Distance units='m'>1000</Distance>
>>    </DWithin>
>> </Filter>
>> and I am having some problems with the units.
>> I specified units='m' but, in the results that I obtain, the distance
>> between the geographical features is in degrees (I checked with ArcMap).
>> Can you help me to solve this problem?
>> Thanks.
>> Best regards.
>> Miguel
>> P.S. If it helps, here is my map object
>> MAP
>>  EXTENT    -36.133725 5.7104918367 66.0633 71.1839
>>  SHAPEPATH    "europe_1_data"
>>  WEB
>>    METADATA
>>    WFS_TITLE    "Mapa da Europa"
>>    WFS_SRS        "http://localhost/cgi-bin/mapserv.exe?"
>>    END
>>  END
>> ############## LAYER cities
>>  LAYER
>>    NAME    cities
>>    DATA    cities
>>    TYPE    line
>>    DUMP    TRUE                                     TOLERANCEUNITS
>> METERS
>>    METADATA
>>    WFS_TITLE    "cities layer"
>>     GML_INCLUDE_ITEMS "all"
>>    END
>>  END
>> ############## LAYER mjroads
>>  LAYER
>>    NAME    mjroads
>>    DATA    mjroads
>>    TYPE    line
>>    DUMP    TRUE
>>    TOLERANCEUNITS METERS
>>    METADATA
>>    WFS_TITLE    "mjroads layer"
>>    END
>>  END
>> ##############LAYER country
>>  LAYER
>>    NAME    countries
>>    DATA    countries
>>    TYPE    polygon
>>    DUMP    TRUE
>>    METADATA
>>    WFS_TITLE    "country layer"
>>    END
>>  END
>> END
