remark on virtualspatialdata-wiki (windows server)
Jeff McKenna jmckenna at DMSOLUTIONS.CA
Fri Sep 16 09:11:17 EDT 2005
Hi Paul,
Newer versions of MS4W have this problem fixed, all of the gdal
reference files are included in /ms4w/gdaldata/ and the environment
variable is set in apache.  Sorry about that.
jeff
Paul wrote:
> i had some problems working out the virtualspatialdata-wiki on my
> windows 2000 server which i'd like to share with you. when i first
> tested my virtual ogr file using ogrinfo, i recieved messages that the
> file gcs.csv could not be opened, containing the projection information.
> The reason was that i hadn't run setenv.bat.
> Later when i tried to view the virtualdatalayer in mapserver i got the
> same messages. Apparently mapserver/apache/ogr also didn't know where to
> look for the projection-files. After introducing the parameter gdal_data
> in apache config the layer was displayed properly.
> SetEnv gdal_data "/ms4w/tools/ogr-utils/data"
> maybe somebody has a different sollution?
> Good luck everybody, working on similar issues,
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
