Dynamical symbol
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Fri Sep 16 09:07:54 EDT 2005
Hi There,
One possible way of doing it is to create (or use already defined)
layer in your map file which is of type circle. Then you should be able
to add a shape object on the fly to this layer. You shape object should
be a line type with 2 points which corresponds to the MBR of the circle.
There might be other ways too.
Later
Gianfranco Brescia wrote:
> Hi to all,
> I need to draw a dynamic circle (position and radius variables) on my map.
> Can I do that with php mapscript?
> How?
> Tanks for answers!
> Ciao
> Gianfranco.
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
