WCS startup problems
Bart van den Eijnden bartvde at XS4ALL.NL
Sat Sep 17 11:33:01 EDT 2005
Hi Frank,
that's a good one, I did not think of that.
Now I get a tiff file which gdalinfo can read, but if I open it up in
OpenEV I don't see anything (black screen).
Can the WCS be used to rasterize vector data or not?
C:\Program Files\FWTools0.9.9>gdalinfo "c:\Documents and
Settings\bart\Desktop\mapserv.tif"
Driver: GTiff/GeoTIFF
Size is 1333, 1333
Coordinate System is:
PROJCS["Amersfoort / RD New",
    GEOGCS["Amersfoort",
        DATUM["Amersfoort",
            SPHEROID["Bessel 1841",6377397.155,299.1528128000009,
                AUTHORITY["EPSG","7004"]],
            AUTHORITY["EPSG","6289"]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433],
        AUTHORITY["EPSG","4289"]],
    PROJECTION["Oblique_Stereographic"],
    PARAMETER["latitude_of_origin",52.15616055555555],
    PARAMETER["central_meridian",5.387638888888889],
    PARAMETER["scale_factor",0.9999079],
    PARAMETER["false_easting",155000],
    PARAMETER["false_northing",463000],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AUTHORITY["EPSG","28992"]]
Origin = (100000.000000,400000.000000)
Pixel Size = (75.01875469,-75.01875469)
Metadata:
  AREA_OR_POINT=Area
Corner Coordinates:
Upper Left  (  100000.000,  400000.000) (  4d35'38.02"E, 51d35'13.69"N)
Lower Left  (  100000.000,  300000.000) (  4d36'33.22"E, 50d41'17.42"N)
Upper Right (  200000.000,  400000.000) (  6d 2'13.48"E, 51d35'16.89"N)
Lower Right (  200000.000,  300000.000) (  6d 1'28.30"E, 50d41'20.54"N)
Center      (  150000.000,  350000.000) (  5d18'58.26"E, 51d 8'25.06"N)
Band 1 Block=1333x6 Type=Byte, ColorInterp=Red
Band 2 Block=1333x6 Type=Byte, ColorInterp=Green
Band 3 Block=1333x6 Type=Byte, ColorInterp=Blue
Best regards,
Bart
Frank Warmerdam wrote:
>On 9/17/05, Bart van den Eijnden <bartvde at xs4all.nl> wrote:
>>Hi list,
>>I am trying to get a basic WCS request running using the Mapserver WCS
>>use cases HOWTO but am only getting corrupt tiff or corrupt ECW files
>>out of Mapserver. Does anybody see what I am doing wrong? I am using the
>>latest fwtools binaries.
>>The request I am trying is:
>>C:\Program Files\FWTools0.9.9>mapserv
>>"QUERY_STRING=map=/ms4w/bart/provincies.map&request=GetCoverage&version=1.0.0&service=WCS&coverage=provincies&
>>bbox=100000,300000,200000,400000&crs=EPSG:28992&resx=75&resy=75&format=GEOTIFF"
>> > out.tif
>Bart,
>You are not removing the "Content-type: image/tiff\n\n" from the
>beginning of he return result.  Whenever I test at the commandlie this
>way I manually edit this out of the result with emacs.  Any editor that
>won't weird-out or "fix" binary files should do.   It is a hassle.
>Best regards,
