Mapserver and threading
Frank Warmerdam
warmerdam at POBOX.COM
Sat Sep 17 23:00:00 EDT 2005
On 9/17/05, Shawn Wallbridge <shawn at synack-hosting.com> wrote:
> I am contemplating the machine I want to run Mapserver on and I am
> trying to decide between a a couple of machines.
> Has anyone run Mapserver on a 4+ CPU machine? Does it thread very well?
> PostGIS will be running on a different machine (Quad Processor Sun
> e450 with 4GB of Ram, lots of SCSI disks running Solaris 10).
Shawn,
The common way of running MapServer is as a cgi (either mapserv
itself, or a mapscript cgi). In this form, each cgi request will run on
a single CPU but several requests can be effectively serviced at a
time.
It is also possible to run MapServer in a multi-threaded way. I
would have to say that this is not so widely used, and consequently
somewhat risky.
So, if you are running as a cgi, then you will be able to support more
requests on a multi-cpu system than on a single cpu system assuming
you find things are cpu bound. Of course, in many cases things are
really input/output or memory bound in which case the multi-cpus will
give relatively little benefit.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
