CLASSITEM-Objekt
Leopold Schefcik (MULTIMEDIAPLAN.AT)
leopold.schefcik at MULTIMEDIAPLAN.AT
Mon Sep 19 07:15:20 EDT 2005
hi list,
I have a layer with polygones and a classitem-object that's working fine.
I want to make the same with an other layer with lines and when I put in the
classitem-object it doesn't works anymore.
Someone has an idea about that?
Best regards,
Leopold
the working poligone Layer:
LAYER
NAME "Bev_Density"
STATUS ON
DATA "test_bevdichte3"
TYPE POLYGON
UNITS METERS
SIZEUNITS PIXELS
TOLERANCE 0
TOLERANCEUNITS PIXELS
METADATA
"wms_title" "Bev_Density"
"DESCRIPTION" "Bevoelkerungsdichte"
"WMS_SRS" "EPSG:31287 EPSG:4326 EPSG:31466 EPSG:31467"
END
STATUS DEFAULT
CLASSITEM 'Bev_class'
CLASS
NAME "sehr niedrige Bevölkerungsdichte"
EXPRESSION "1"
COLOR 255 227 231
OUTLINECOLOR 101 79 79
SIZE 2
END
the same with a line layer - not working (without the classitem object it
works)
LAYER
NAME "BMVIT_wms_strasse_2010"
STATUS ON
DATA "strasse_2010_lambert475"
TYPE LINE
CLASSITEM "BELFZGIV1"
UNITS METERS
SIZEUNITS PIXELS
MINSCALE 1
MAXSCALE 5000000
TOLERANCE 0
METADATA
"wms_title" "BMVIT_wms_strasse_2010"
"DESCRIPTION" "BMVIT Verkehrsprognose strasse_2010"
END
STATUS DEFAULT
CLASSITEM 'fzgiv'
CLASS
NAME "0 bis 3000 KFZ/Tag"
EXPRESSION "1"
COLOR 254 225 225
SIZE 2
END
