CLASSITEM-Objekt
Michael Schulz
mschulz at WEBGIS.DE
Mon Sep 19 08:02:04 EDT 2005
Hi Leopold,
seems you have two classitems defined for the line layer: CLASSITEM
"BELFZGIV1" and CLASSITEM 'fzgiv'. Maybe that's all.
Cheers, Michael
Leopold Schefcik (MULTIMEDIAPLAN.AT) schrieb:
> hi list,
> I have a layer with polygones and a classitem-object that's working fine.
> I want to make the same with an other layer with lines and when I put in the
> classitem-object it doesn't works anymore.
> Someone has an idea about that?
> Best regards,
> Leopold
> the working poligone Layer:
> LAYER
> NAME "Bev_Density"
> STATUS ON
> DATA "test_bevdichte3"
> TYPE POLYGON
> UNITS METERS
> SIZEUNITS PIXELS
> TOLERANCE 0
> TOLERANCEUNITS PIXELS
> METADATA
> "wms_title" "Bev_Density"
> "DESCRIPTION" "Bevoelkerungsdichte"
> "WMS_SRS" "EPSG:31287 EPSG:4326 EPSG:31466 EPSG:31467"
> END
> STATUS DEFAULT
> CLASSITEM 'Bev_class'
> CLASS
> NAME "sehr niedrige Bevölkerungsdichte"
> EXPRESSION "1"
> COLOR 255 227 231
> OUTLINECOLOR 101 79 79
> SIZE 2
> END
> the same with a line layer - not working (without the classitem object it
> works)
> LAYER
> NAME "BMVIT_wms_strasse_2010"
> STATUS ON
> DATA "strasse_2010_lambert475"
> TYPE LINE
> CLASSITEM "BELFZGIV1"
> UNITS METERS
> SIZEUNITS PIXELS
> MINSCALE 1
> MAXSCALE 5000000
> TOLERANCE 0
> METADATA
> "wms_title" "BMVIT_wms_strasse_2010"
> "DESCRIPTION" "BMVIT Verkehrsprognose strasse_2010"
> END
> STATUS DEFAULT
> CLASSITEM 'fzgiv'
> CLASS
> NAME "0 bis 3000 KFZ/Tag"
> EXPRESSION "1"
> COLOR 254 225 225
> SIZE 2
> END
Michael Schulz mschulz at webgis.de
in medias res Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66 Tel +49 (0)761 556959-5
79108 Freiburg Fax +49 (0)761 556959-6
www.webgis.de / www.zopecms.de
NEU ++ UMN MapServer Hosting ++ http://www.webgis.de ++ NEU
