MAPSERVER-USERS Digest - 24 Sep 2005 to 25 Sep 2005
(#2005-277)
thomas bonfort
thomas.bonfort at GMAIL.COM
Mon Sep 26 12:08:29 EDT 2005
hi,
I don't quite understand, what you mean when you say that the layer becomes
a polyline, isn't that exactly what you're looking for ?
if you want an empty polygon , you do exactly as you said, defining the
"outlinecolor" and not "color".
cheers, tb
On 9/26/05, shailesh gavavthe <sgavathe at yahoo.co.in> wrote:
> Hi All ,
> I am a developing mapserver 4.60 with PHP.
> My mapfiles has some polygon layers, Aerial Photos and Line layes.
> One of Polygon layer which is Parcel Information covers the size of
> entire aerial Photos.
> I want the Polygon layer (Hollow) and so that it can rest on the top of
> Aerial Photo.
> I am also developing web application.
> Could any one let me know, How will i be able to get the Polygon
> Unfilled(Hollow) and resting on top of aerial Photo..
> here is my Map File and the Order of the Layers is the one below..
> LAYER # All RASTER Layers TIFFIMAGE begin here
> TYPE RASTER
> #MINSCALE 2000
> MAXSCALE 20000 #750000
> STATUS OFF
> NAME "EDWARDS-NorthEast"
> DATA "Aerial Photo\edwards_ne_ILS1.tif"
> PROCESSING "BANDS=1,2,3"
> OFFSITE 255 255 255
> END # layer ends here ---------------
> LAYER # All VECTOR Layers begins here
> NAME Parcel
> METADATA
> #"DESCRIPTION" "parcel_polygon"
> "DESCRIPTION" "Unplatted Parcel"
> "RESULT_FIELDS" "PID ParcelName CalAcreage"
> END # end of Metadata----------------
> DATA "Unplatted Parcel\parcel_polygon.shp"
> STATUS DEFAULT
> TYPE POLYGON
> #MAXSCALE 10000
> LABELITEM "PID"
> LABELMAXSCALE 16000
> TOLERANCE 3
> TRANSPARENCY 1000
> CLASS
> NAME 'Parcel'
> TEMPLATE "templates/Parcel.html"
> STYLE
> #COLOR 255 255 255
> SYMBOL 0
> COLOR -1 -1 -1
> OUTLINECOLOR 0 0 0
> END
> LABEL # start of label
> COLOR 0 0 0
> #SHADOWCOLOR 255 255 0
> #SHADOWSIZE 0 0
> TYPE TRUETYPE
> FONT arial-bold
> SIZE 8
> ANTIALIAS TRUE
> ANGLE AUTO
> POSITION LC
> PARTIALS FALSE
> MINDISTANCE 300
> BUFFER 0
> END # end of label//////////////
> END
> If i uncomment the OutlinecColor and comment Color , the selected layers
> becomes polyine.
> And when i put Both of them uncommented, the shapefiles is filled
> polygon.
> After that in the web application, the selcted layers is highlighted with
> filled polygon, *But the aerial Photo becomes invisible, because Layer is
> Polygon and Filled.*
> *I would really appreciate, if some one could have a solution on it.*
> *Thanks in Advance..*
> *SHAIL*
> *Home PG : http:/people.emich.edu/sgavathe*
> *MAPSERVER-USERS automatic digest system <LISTSERV at LISTS.UMN.EDU>* wrote:
> [image: Skip repetitive navigational links]<http://us.f83.mail.yahoo.com/ym/Compose?box=Inbox&Mid=4541_7366369_2887607_1626_2971_0_29784_8209_1265582234&inc=&Search=&YY=26413&order=down&sort=date&pos=0#skipnavlinks> [image:
> L-Soft - Home of the LISTSERV mailing list manager]<http://www.lsoft.com/> [image:
> LISTSERV(R) 14.3] MAPSERVER-USERS Digest - 24 Sep 2005 to 25 Sep 2005
> (#2005-277)
> Table of contents:
> - WMS, convert GetCapabilites XML to Map Context XML<http://us.f83.mail.yahoo.com/ym/Compose?box=Inbox&Mid=4541_7366369_2887607_1626_2971_0_29784_8209_1265582234&inc=&Search=&YY=26413&order=down&sort=date&pos=0#S1>
> - File permissions set randomly on Apache<http://us.f83.mail.yahoo.com/ym/Compose?box=Inbox&Mid=4541_7366369_2887607_1626_2971_0_29784_8209_1265582234&inc=&Search=&YY=26413&order=down&sort=date&pos=0#S2>(2)
> 1. WMS, convert GetCapabilites XML to Map Context XML
> - Re: WMS, convert GetCapabilites XML to Map Context XML(09/25)
> *From:* Armin Burger <armin.burger at GMX.NET>
> 2. File permissions set randomly on Apache
> - File permissions set randomly on Apache (09/25)
> *From:* Alan Hale <alan.hale at BTCLICK.COM>
> - Re: File permissions set randomly on Apache (09/25)
> *From:* Prashanth Ram <pram123 at GMAIL.COM>
> [image: Powered by LISTSERV(R)]<http://www.lsoft.com/LISTSERV-powered.html> Browse
> the MAPSERVER-USERS online archives.<http://lists.umn.edu/cgi-bin/wa?LIST=MAPSERVER-USERS> Date:
> Sun, 25 Sep 2005 21:14:23 +0200
> From: Armin Burger <armin.burger at GMX.NET>
> Subject: Re: WMS, convert GetCapabilites XML to Map Context XML
> Tom,
> thanks for the link. The Caps2Context.xsl is in fact for WMS. There seem
> to be just some small discrepancies between the output of the template
> and what the MapScript loadMapContext() function requires, but this
> needs just slight modification of the XSL.
> Armin
> Kralidis,Tom [Burlington] wrote:
> > The mapbuilder project (http://mapbuilder.sourceforge.net/) has a WFS
> > Capabilities to WMC xsl in lib/tool/xsl/Caps2Context.xsl.
> > There's one over at
> > http://geoservices.cgdi.ca/mapbuilder/lib/tool/xsl/Caps2Context.xsl.
> > You can probably modify it for WMS, and hopefully contribute it to the
> > project!
> > Cheers
> > ..Tom
> >>-----Original Message-----
> >>From: UMN MapServer Users List
> >>[mailto:MAPSERVER-USERS at lists.umn.edu] On Behalf Of Armin Burger
> >>Sent: Saturday, 24 September, 2005 08:48
> >>To: MAPSERVER-USERS at lists.umn.edu
> >>Subject: [UMN_MAPSERVER-USERS] WMS, convert GetCapabilites
> >>Hi everybody,
> >>MapScript offers the nice functionality to add WMS layers via a Map
> >>Context XML file.
> >>I would like to convert the XML received from a
> >>GetCapabilites request
> >>into a Map Context XML document and load this Map Context XML file as
> >>layers into the map object. I think XSL transformation could
> >>be a good
> >>solution to do this conversion. Has anybody already worked on an XSLT
> >>template to convert the GetCapabilites XML into a Map Context
> >>XML document?
> >>Armin
> Date: Sun, 25 Sep 2005 21:20:51 +0100
> From: Alan Hale <alan.hale at BTCLICK.COM>
> Subject: File permissions set randomly on Apache
> New to Mapserver and to this list. I've been doing some initial
> development on IIS locally and now wanting to move to a remote (virtual)
> host running Unix/Apache. Working OK except that the file permissions on
> the map image files seem to be created with permissions varying,
> apparently at random, so that sometimes they are displayed, sometimes
> not.
> I've checked the archives but not been able to fin this exact problem
> described. Any help very welcome.
> Alan Hale
> Bryo Software Solutions
> Aberystwyth Wales
> No virus found in this outgoing message.
> Checked by AVG Anti-Virus.
> Version: 7.0.344 / Virus Database: 267.11.6/111 - Release Date:
> 23/09/2005
> Date: Sun, 25 Sep 2005 18:14:24 -0400
> From: Prashanth Ram <pram123 at GMAIL.COM>
> Subject: Re: File permissions set randomly on Apache
> Alan:
> Who/what are the file permissions set as? Also, what OS/apache version?
> -Prashanth
> HTMLX.com
> Mapserver Hosting, Mapscript Hosting, PHP Hosting
> PostgreSQL w/PostGIS extension enabled Hosting
> > not.
> > Alan Hale
> > Aberystwyth Wales
> > 23/09/2005
> Shailesh gavathe
> 516 ,St Johns Street,
> Apt # 102,ypsilanti,
> MI-48197.
> Ph : 734-482-0832
> URL : http://people.emich.edu/sgavathe
> Yahoo! for Good
> Click here to donate <http://store.yahoo.com/redcross-donate3/> to the
> Hurricane Katrina relief effort.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050926/9be74984/attachment.html
