routing
Daniel daniel.faivre at CAMPTOCAMP.COM
Mon Sep 26 12:32:42 EDT 2005
When we decided to add a routing extension to Postgresql, we tried
several libraries, including dglib.
The boost library was found more efficient, and more flexible.
DGLib is used  by Grass
Daniel FAIVRE
Paolo Cavallini wrote:
>Thanks to all who responded. Quite reassuring to see that the solution I had
>in mind are those you suggested.
>I never used the pg module; is it possible to define only one start and end
>point, or can I select multiple points?
>I have cursorily read the README, but could not find it.
>As Stephan pointed out, I would be inclined towards GRASS, but the database
>approach seems more compact. Anybody has tried both methods, and can
>arguments about respective merits?
>Again, many thanks.
>pc
>At 12:40, mercoledì 21 settembre 2005, Norman Barker has probably written:
>>-----Original Message-----
>>Paolo,
>>there is a brillant postgres extension called "pgdijkstra" from
>>camp2camp. You need postgres 8.0. It delivers an algorythm for
>>calculating the shortest path - you also may alter this by other
>>attributes, because you are in the database.
>>It's a horror to get the first data into the db (I can help) - if once
>>done it is quite easy and afterwards it's easy to handle.
>>Till
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050926/cf6dcf89/daniel.faivre.vcf
