TRANSPARENCY
Bart van den Eijnden BEN at SYNCERA-ITSOLUTIONS.NL
Wed Sep 28 05:46:57 EDT 2005
Which output format are you using Leopold?
Does that support transparency? Can you POST the OUTPUTFORMAT definition from your MAP file?
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG  DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> "Leopold Schefcik (MULTIMEDIAPLAN.AT)"              <leopold.schefcik at MULTIMEDIAPLAN.AT> 09/28/05 11:43 AM >>>
Hi list,
I want to give a layer TRANSPARENCY.
when I set TRANSPARENCY 85 ist more dark then TRANSPARENCY 25, but you still
can't see the other layers behind it.
Best regards
Leopold
