AW: TRANSPARENCY
Leopold Schefcik (MULTIMEDIAPLAN.AT)
leopold.schefcik at MULTIMEDIAPLAN.AT
Wed Sep 28 06:53:23 EDT 2005
hi Bart,
here is the Outputfomat and Layer:
OUTPUTFORMAT
NAME "png"
MIMETYPE "image/png"
DRIVER "GD/PNG"
EXTENSION "png"
IMAGEMODE PC256
TRANSPARENT FALSE
END
LAYER
NAME "CE_extract_centrope_region"
STATUS ON
DATA "CE_CE_ADMIN_GENRL_OUTSIDECENTROPE_XXXX"
TYPE POLYGON
UNITS METERS
SIZEUNITS PIXELS
MINSCALE 1
MAXSCALE 100000000
TOLERANCE 0
TOLERANCEUNITS PIXELS
METADATA
"wms_title" "CE_extract_centrope_region"
"DESCRIPTION" "Extract Centrope Region"
"WMS_SRS" "EPSG:31287 EPSG:4326 EPSG:31466 EPSG:31467"
END
TRANSPARENCY 25
CLASS
STYLE
SYMBOL 0
COLOR 230 230 230
OUTLINECOLOR 101 79 79
BACKGROUNDCOLOR 251 148 112
SIZE 1
MINSIZE 1
MAXSIZE 100
END
END
END
-----Ursprungliche Nachricht-----
Von: Bart van den Eijnden [mailto:BEN at Syncera-ITSolutions.NL]
Gesendet: Mittwoch, 28. September 2005 11:47
An: MAPSERVER-USERS at LISTS.UMN.EDU; leopold.schefcik at MULTIMEDIAPLAN.AT
Betreff: Re: [UMN_MAPSERVER-USERS] TRANSPARENCY
Which output format are you using Leopold?
Does that support transparency? Can you POST the OUTPUTFORMAT definition
from your MAP file?
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> "Leopold Schefcik (MULTIMEDIAPLAN.AT)"
<leopold.schefcik at MULTIMEDIAPLAN.AT> 09/28/05 11:43 AM >>>
Hi list,
I want to give a layer TRANSPARENCY.
when I set TRANSPARENCY 85 ist more dark then TRANSPARENCY 25, but you still
can't see the other layers behind it.
Best regards
Leopold
