AW: TRANSPARENCY
Bart van den Eijnden BEN at SYNCERA-ITSOLUTIONS.NL
Wed Sep 28 07:02:56 EDT 2005
Hi Leopold,
can you try IMAGEMODE RGBA instead of IMAGEMODE PC256?
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG  DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> "Leopold Schefcik (MULTIMEDIAPLAN.AT)"              <leopold.schefcik at MULTIMEDIAPLAN.AT> 09/28/05 12:53 PM >>>
hi Bart,
here is the Outputfomat and Layer:
  OUTPUTFORMAT
    NAME "png"
    MIMETYPE "image/png"
    DRIVER "GD/PNG"
    EXTENSION "png"
    IMAGEMODE PC256
    TRANSPARENT FALSE
  END
  LAYER
    NAME "CE_extract_centrope_region"
    STATUS ON
    DATA "CE_CE_ADMIN_GENRL_OUTSIDECENTROPE_XXXX"
    TYPE POLYGON
    UNITS METERS
    SIZEUNITS PIXELS
	MINSCALE   1
    MAXSCALE 100000000
    TOLERANCE 0
    TOLERANCEUNITS PIXELS
    METADATA
      "wms_title"    "CE_extract_centrope_region"
      "DESCRIPTION"    "Extract Centrope Region"
      "WMS_SRS"    "EPSG:31287 EPSG:4326 EPSG:31466 EPSG:31467"
    END
	TRANSPARENCY 25
    CLASS
      STYLE
        SYMBOL 0
        COLOR 230 230 230
        OUTLINECOLOR 101 79 79
        BACKGROUNDCOLOR 251 148 112
        SIZE 1
        MINSIZE 1
        MAXSIZE 100
      END
    END
  END
-----Ursprungliche Nachricht-----
Von: Bart van den Eijnden [mailto:BEN at Syncera-ITSolutions.NL]
Gesendet: Mittwoch, 28. September 2005 11:47
An: MAPSERVER-USERS at LISTS.UMN.EDU; leopold.schefcik at MULTIMEDIAPLAN.AT
Betreff: Re: [UMN_MAPSERVER-USERS] TRANSPARENCY
Which output format are you using Leopold?
Does that support transparency? Can you POST the OUTPUTFORMAT definition
from your MAP file?
Best regards,
Bart
Postbus 270
2600 AG  DELFT
<leopold.schefcik at MULTIMEDIAPLAN.AT> 09/28/05 11:43 AM >>>
Hi list,
I want to give a layer TRANSPARENCY.
when I set TRANSPARENCY 85 ist more dark then TRANSPARENCY 25, but you still
can't see the other layers behind it.
Best regards
Leopold
