Grids vs. Graticules
Chip Taylor
work at XWB.COM
Wed Sep 28 12:47:59 EDT 2005
I am new to Mapserver, deep in the learning curve. I have a question that
I hope someone can answer. If I add a Grid layer to the map file the map
draws the grid with no problem. However, I need the grid to be displayed as
graticules, that is, distorted as lines of latitude and longitude are
distorted depending on the projection. Instead the grid lines are all true
vertical, horizontal. Is this possible?
Here is the Grid Layer in my mapfile:
# GRID
LAYER
NAME "Grid"
TYPE LINE
STATUS DEFAULT
CLASS
NAME "Graticule"
COLOR 0 0 0
LABEL
COLOR 255 0 0
FONT "arial"
TYPE truetype
SIZE 8
POSITION auto
PARTIALS false
BUFFER 5
OUTLINECOLOR 255 255 255
END
END
GRID
LABELFORMAT DDMM
MAXARCS 10
MINARCS 2
MAXINTERVAL 20
MININTERVAL 10
MAXSUBDIVIDE 40
MINSUBDIVIDE 2
END
END
Chip Taylor
Prepared Response, Inc
Chip Taylor
Prepared Response, Inc.
1127 Broadway Plaza, Suite 204
Tacoma, WA 98402
O 253.272.1730
M 253.948.2525
STATEMENT OF CONFIDENTIALITY
The information contained in this electronic message and any attachments to
this message are intended for the exclusive use of the addressee(s) and may
contain confidential or privileged information. If you are not the intended
recipient, please notify Prepared Response, Inc. immediately at (206)
223-5544 and destroy all copies of this message and any attachments.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050928/45b7a2b7/attachment.html
