Grids vs. Graticules
Randy James rjames57 at YAHOO.COM
Wed Sep 28 13:05:29 EDT 2005
Hi Chip
You need the projection defined in your grid layer, if it is a different
projection than the projection of the map file.
Randy
--- Chip Taylor <work at XWB.COM> wrote:
>  I am new to Mapserver, deep in the learning curve.  I have a question that
> I hope someone can answer.  If I add a Grid layer to the map file the map
> draws the grid with no problem.  However, I need the grid to be displayed as
> graticules, that is, distorted as lines of latitude and longitude are
> distorted depending on the projection.  Instead the grid lines are all true
> vertical, horizontal.  Is this possible?
> Here is the Grid Layer in my mapfile:
> #  GRID
> LAYER
>   NAME "Grid"
>   TYPE LINE
>   STATUS DEFAULT
>   CLASS
>     NAME "Graticule"
>     COLOR 0 0 0
>     LABEL
>       COLOR 255 0 0
>       FONT "arial"
>       TYPE truetype
>       SIZE 8
>       POSITION auto
>       PARTIALS false
>       BUFFER 5
>       OUTLINECOLOR 255 255 255
>     END
>   END
>   GRID
>     LABELFORMAT DDMM
>     MAXARCS 10
>     MINARCS 2
>     MAXINTERVAL 20
>     MININTERVAL 10
>     MAXSUBDIVIDE 40
>     MINSUBDIVIDE 2
>   END
> END
> Chip Taylor
> Prepared Response, Inc
> Chip Taylor
> Prepared Response, Inc.
> 1127 Broadway Plaza, Suite 204
> Tacoma, WA  98402
> O 253.272.1730
> M 253.948.2525
> STATEMENT OF CONFIDENTIALITY
> The information contained in this electronic message and any attachments to
> this message are intended for the exclusive use of the addressee(s) and may
> contain confidential or privileged information. If you are not the intended
> recipient, please notify Prepared Response, Inc. immediately at (206)
> 223-5544 and destroy all copies of this message and any attachments.
__________________________________
Yahoo! Mail - PC Magazine Editors' Choice 2005
http://mail.yahoo.com
