Php4 vs PHP5
david techer
davidtecher at YAHOO.FR
Thu Sep 29 05:17:20 EDT 2005
Hi Fabio
I'm on a Debian like you.
I've built both mapscript 4.6.1 and php 5.0.5 from sources
For my tasks at my job, there is no problem using both.
I've installed php as CGI
Here is my PHP configure line:
./configure --enable-fastcgi --with-config-file=/usr/lib/cgi-bin/php.ini \
--with-gd=/usr --with-pdflib=/usr/local --with-png-dir=/usr \
--with-freetype-dir=/usr --with-zlib=/usr --with-pgsql \
--with-regex=system --enable-dbase --enable-dbx \
--with-jpeg-dir=/usr --enable-versioning --with-mysql \
--with-ming
For MapServer:
./configure --without-tiff --with-jpeg=/usr --with-png=/usr --with-threads --with-proj \
--with-postgis --with-pdf --with-mapscript --with-gdal=/usr/local/bin/gdal-config \
--with-gd=/usr --with-freetype=/usr --with-ogr --with-wmsclient --with-wfs --with-wfsclient \
--with-php=/home/david/src/PHP/php-5.0.5 --with-geos --with-ming
For a better use and a first try, I think it's not worth using 'Flash Support' (--with-ming) and
'PDFLIB Support' (-with-pdflib) if U don't want to have it
However, here is what I did to have it
Info:
- PDFLIB version is 5.0.3. It is not yet supported (but I need it for my job)
New versions from 6... are available so U can use it.
Download it then ./configure && make && make install
- Ming has been built from CVS. In ming/util/read.h, replace 'static int gIndent;' by ' 'static int gIndent;' in order to compil it
then
make
make install
Remove everything from your-php-sources/ext/ming/
Copy everything from your-ming-sources/php_ext/ to your-php-sources/ext/ming/
Return to your php-sources directory
cd your-php-sources/
buildconf --force
Then
./configure .... .... --with-ming --with-pdflib=/usr/local
Regards
--david;
Jean David TECHER
01MAP
35 Allée d'Irlande
34080 Montpellier
France
Tél: 04 67 45 60 27
e-mail: davidtecher(at)yahoo(dot)fr
sites: http://www.postgis.fr
http://techer.pascal.free.fr/postgis/
Fabio Zottele a écrit :
> Hi! I am using Apache2-prefork (Debian package) and php4 -DSO(Dabian
> package) on a Debian testing. I want to install mapserver4.6.1 from
> source code. I know I must re-compile php as a CGI, but I would also
> migrate from php4.4 to php5.
> I read some old issues about php_mapscript.so and php5 in mailing list.
> Is still impossible to compile php_mapscript against php5 or the php5
> support is still in developement stage?
> Thank you in advance.
> Fabio Zottele
___________________________________________________________________________
Appel audio GRATUIT partout dans le monde avec le nouveau Yahoo! Messenger
Téléchargez cette version sur http://fr.messenger.yahoo.com
