Problem with ms_newShapeFileObj
Gianfranco Brescia
ajfrank at ALICE.IT
Thu Sep 29 12:32:52 EDT 2005
I can not create a new point into my shape, can somebody help me?
This my code:
if ($dbval["CODICE_ALL"] && $dbval["COGNOME"] && $dbval["NUM_ALBO"])
$shpPath = "../webgis/dati/lombardia/polli/polli";
$dbName = "../webgis/dati/lombardia/polli/polli.dbf";
$poiClick = ms_newPointObj();
$poiClick->setXY($xgeo, $ygeo);
if ( !$dbf = dbase_open($dbName, 2) )
echo "Impossibile aprire $dbName\n";
exit;
$nr = dbase_numrecords($dbf); // numero record del database
$nr = $nr +1; // numero nuovo recordo
$nf = dbase_numfields($dbf); // Numero campi database
$shpFile = ms_newShapefileObj($shpPath, -2);
$shpObj = ms_newShapeObj(MS_SHAPE_POINT);
$lineObj = ms_newLineObj();
$bSuc = $lineObj->add($poiClick);
$bSuc = $shpObj->add($lineObj);
$bSuc = $shpFile->addShape($shpObj);
$nShapes = $shpFile->numshapes;
dbase_add_record($dbf, array($nr, $dbval["CODICE_ALL"],$dbval["COGNOME"],
$dbval["NUM_ALBO"], $dbval["DATA"], $dbval["EST"], $dbval["NORD"]));
$poiClick->free();
$lineObj->free();
$shpObj->free();
$shpFile->free();
dbase_close($dbf);
When I try to draw the map the error is:
Warning: [MapServer Error]: msDrawMap(): Failed to draw layer named 'polli'.
in /usr/local/apache2/htdocs/tpk/incphp/map.php on line 354
Warning: [MapServer Error]: msDBFGetItemIndex(): Invalid record number
24943. in /usr/local/apache2/htdocs/tpk/incphp/map.php on line 354
Fatal error: Call to a member function saveWebImage() on a non-object in
/usr/local/apache2/htdocs/tpk/incphp/map.php on line 376
Thank, ciao.
