FW: [UMN_MAPSERVER-USERS] Problem with display of raster
backdrop -- ECW files with overlap
Frank Warmerdam
warmerdam at POBOX.COM
Thu Sep 29 15:55:56 EDT 2005
On 9/29/05, Stephen Clark <SClark at county.lethbridge.ab.ca> wrote:
> Frank,
> When you have some time could you investigate this problem.
> Generally speaking if I create a tile using GDALTINDEX for a group of
> ECW
> Raster images that overlap, I cannot draw the raster tile index.
> However If I convert the ECW files to Geotiff and then create a tile
> Using GDALTINDEX using your FWTOOLS then I am able to draw the raster
> layer.
> Also, Is there anyone else that has seen this problem.
Stephen,
I have fixed a signicant but in GDAL with the ECW driver that would
occur at the point ECW (or jp2) files are closed. It seems possible
that this is the problem that is afflicting you. If so, updating to the
latest gdal code from CVS would help.
However, it is hard to know if that is the issues.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
