Long generation time of map images in mapserver
Hal Mueller
hal at MOBILEGEOGRAPHICS.COM
Wed Dec 6 14:52:28 EST 2006
Is there any chance that you have omitted the ellipsoid in your
projection definition?
I had several mapfiles without it. They worked fine on 4.2, but
sometimes were very slow on 4.6. When I went to 4.10 I started
seeing the error message at
http://mapserver.gis.umn.edu/docs/error/axis-radius . Interestingly
though, I didn't see it every time. I could reload the exact same
map, and sometimes it would throw the error, sometimes not.
Once I fixed that, the slow rendering maps got fast again.
At 2:39 PM -0500 12/6/06, Thomas Shaw wrote:
>Hello List!
>I have actually installed mapserver-4.8.4 & PHP5 (as a dynamic library of
>mapscript) in my production server and I'm experiencing some strange
>behavior (that I haven't had with the 4.2 version) with the mapserver
>generation time of the images maps. Sometimes I zoom in/out and the image
>generations take less than a second, but also some other times the
>generation takes about 12 seconds. Firstly I thought that it was the
>internet connection, but I tried it also over the LAN and it had the same
>strange behavior. So what could be possible happening?
>When I changed from mapserver 4.2 to 4.8.4 I didn't modified any parameter
>of value in the mapscript, and in the mapfile.
>Thank you in advance
