Polygon buffer?
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Fri Dec 8 16:40:49 EST 2006
Jason: MapServer does support this, either via the CGI or using
MapScript.
MapServer's feature or shape query methods do support distance
computations.
The result set mimics doing a buffer on the selection shape first and
then applying
it looking for intersections/overlap.
Distances are set within the layer to be searched using TOLERANCE and
TOLERANCEUNITS
so you could do something like:
- select a lake
- find all boat landings within 500 ft
- find all state parks within 50 miles
- find all steams with 1 km
All with one query. I don't have a good example laying around, but it's
easy enough
to setup. Here's a featurenquery example that selects a county and all
quads that
intersect it. If you set layer tolerances for the quad layers being
searched you'd
get what I described above.
Steve
>>> "Sievers, Jason" <jsievers at CO.LINN.OR.US> 12/8/2006 1:27:47 PM >>>
I want to perform a buffer query around a polygon. I would select a
polygon, then get features from another layer who are within a
specified
distance of the outside edge of my selected polygon. The only queries
involving buffers I see in the documentation are on points. I have
looked
briefly at PostGIS and GRASS documentation. Is the solution possible
in
MapServer? or should I investigate PostGIS, GRASS, or other tools?
Thanks for any help.
Jason Sievers
jsievers at co.linn.or.us
