ÈÝìá: Re: [UMN_MAPSERVER-USERS] truetype fonts problem...
Graham Berry at Virgin
g.berry at VIRGIN.NET
Mon Dec 11 07:15:06 EST 2006
I have just solved the same problem and this is the snippet from my map file. You are probably aware that you need to be careful of the font you are using to old your data. If you are using iso8859-n (Greek) then you need a font with those characters in the upper 128 character positions. However if you are using UTF-8 encoding then use the arial.ttf font and you will get support for all/most of the iso8859-n range of character sets.
My next trick is to try the new “Arial Unicode ms” font for far east languages.
Hope this helps.
Graham Berry
gberry at qpqsoftware.com
MAP
# Start of map file
NAME "Bulgaria"
STATUS ON
EXTENT 22.097 44.508 28.857 40.653
SIZE 500 500
SHAPEPATH "shpdata"
SYMBOLSET "symbols/symbols.sym"
FONTSET "/htdocs/www/v2/map_bulgaria/symbols/fonts.txt"
IMAGECOLOR 200 200 200
UNITS DD
# you may need to change this to match your MapServer build
IMAGETYPE PNG
# Start of web interface definition (including WMS enabling metadata)
# Start of legend
LEGEND
STATUS ON
KEYSIZE 18 12
LABEL
TYPE TRUETYPE
FONT arial
SIZE 10
COLOR 0 0 138
END
END
LAYER
NAME "ZZ"
STATUS DEFAULT
TYPE POINT
TOLERANCE 5
CLASS
NAME "##-##EditLocation"
SYMBOL 4
COLOR 0 0 0
SIZE 8
MINSIZE 1
MAXSIZE 100
LABEL
TYPE TRUETYPE
FONT arial
SIZE 8
POSITION AUTO
COLOR 0 0 0
OUTLINECOLOR 255 255 255
PARTIALS FALSE
END
END
# INSERT EDIT LOCATION {Dynamic points added at runtime}
END
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of korakas koarkis
Sent: 11 December 2006 11:58
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Θέμα: Re: [UMN_MAPSERVER-USERS] truetype fonts problem...
Thanks for the quick repsonses.
I used an absolute path to the fontset.txt:
arial C:\ms4w\Apache\htdocs\gp\font\arial.ttf
and in the map file I refer only to arial truetype fonts but the problem remains!
msGetLabelSize(): TrueType Font error. Requested font (arial) not found.
Also the arial.ttf file is a copy from the C:\windows\fonts directory so it is not corrupt..
kio
boice tomlin <boice at runskip.com> έγραψε:
Hello,
I would start by using an absolute path to the fontset.txt file to see if the relative path is the problem.
Then I would try using just one font in the list and see if you can get that working. If it can find the arial font but not the arialbd then maybe that font file is corrupt.
-boice
On Dec 8, 2006, at 12:02 PM, korakas koarkis wrote:
Hi all,
I want to use true type fonts in my maps and I am using the following setup:
a "font" folder with: arial.ttf arialbd.ttf.
also in this folder is placed the fontset.txt:
arial arial.ttf
arialbd arialbd.ttf
and finally in my map file
FONTSET "..\font\fontset.txt"
LABEL
TYPE truetype
FONT arialbd
SIZE 9
but the mapserver produces ::
msGetLabelSize(): TrueType Font error. Requested font (arialbd) not found.
I am completely stuck here.
The mapserver sees the fontset.txt, (if i rename it it produces an repsective error message) but it can not read the aliases!
kio
_____
Χρησιμοποιείτε Yahoo!
Βαρεθήκατε τα ενοχλητικά μηνύ ματα (spam); Το Yahoo! Mail διαθέτει την καλύτερη δυνατή προστασία κατά των ενοχλητικών μηνυμάτων
http://login.yahoo.com/config/mail?.intl=gr
Run Skip
http://runskip.com/
boice tomlin
503-528-6204
_____
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061211/64cf4d37/attachment.html
