alpha transparency and querymap
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Fri Dec 15 14:27:45 EST 2006
Jim: What does the querymap def look like? What TYPE are you using?
Steve
>>> Jim White <jbw2003 at earthlink.net> 12/13/2006 8:29:28 PM >>>
Steve,
First some of the mapfile:
OUTPUTFORMAT
NAME mypng
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE rgba
EXTENSION "png"
TRANSPARENT ON
END
LAYER
CONNECTIONTYPE postgis
NAME "counties_q"
CONNECTION "user=postgres dbname=mydb host=localhost"
DATA "wkb_geometry FROM county"
STATUS OFF
TYPE POLYGON
TRANSPARENCY alpha
CLASS
STYLE
SYMBOL 'hatch-lines'
COLOR 255 0 0
ANGLE 60
SIZE 10
END
STYLE
WIDTH 2
OUTLINECOLOR 255 0 0
END
TEMPLATE "dummy.html"
END
END
Here's the PHP/mapscript for one of the layers that's used to display
items the user selects from a select box. The idea is to create a
transparent hatch pattern over a user created area of interest before
it
is submitted. This is currently working with the maps we have but we
might like to add a satellite background or a shaded dem background,
which I imagine will look better in true color.
$this_layer = $map->getLayerByName('counties_q');
$this_layer->set('status', MS_OFF);
if (isset($key_counties)) $this_layer->set('status', MS_ON);
$layer_index = $this_layer->index;
for($i=0; $i<count($key_counties); $i++){
@$map->queryByIndex($layer_index,1,$key_counties[$i], MS_TRUE);
and followed eventually by:
$queryimage = $map->drawQuery();
$queryimage->saveImage($maploc);
The counties_q layer will properly display in rgba mode if I just set
it
to default and don't use the queryByIndex method to select particular
elements in the layer. It will also display properly in 256 color mode
using queryByIndex. However, when I use queryByIndex in rgba mode the
hatch pattern is not transparent and has the white background.
Thanks,
Jim
Steve Lime wrote:
> My guess is it's a bug in the querymap code. On occasion developers
will
> update
> the main drawing code and forget about that other path.
> Tell me more about your setup (PHP,CGI or ?, what type of
querymap?).
> There may
> be a workaround (almost always is) using standard maps...
> Steve
>>>> Jim White <jbw2003 at EARTHLINK.NET> 12/12/06 9:19 PM >>>
> I am having a continuing problem using alpha transparency and
querymap.
> I want to display my map in true color, so have set imagemode to
rgba.
> Additionally, I have defined a hatch-lines symbol that I want to
display
> in transparent mode. I am using the queryByIndex method to select
the
> items to display in the layer. I have tried many combinations, but
still
> get a white background behind the hatch-lines instead of the
background
> map.
> Will appreciate any help to find a fix or to determine whether this
is a
> bug in querymap.
> Thanks,
> Jim
Jim White
Biodiversity and Spatial Information Center
North Carolina State University
http://www.basic.ncsu.edu/
