mapserver raster documentation
Frank Warmerdam
warmerdam at POBOX.COM
Sat Dec 16 18:34:25 EST 2006
John Mitchell wrote:
> Hi,
> I have been reading over the mapserver raster documentation and I have a
> few questions:
> 1.) It mentioned a 4 gb limit for GeoTiff files. Is this for GeoTiff
> files or that GeoTiff's can only be tiled up to 4 gb. Is this 4 gb
> limit an issue with mapserver or GeoTiff.
John,
The 4GB limit is inherent in TIFF, and it isn't specific to mapserver
in any way. Note that you can setup a tile index with my TIFF files
smaller than 4GB. There is no meaningful limit on the amount of data
that can be in a tileindex.
> 2.) Assuming the 4 gb GeoTiff limit then the GeoTiff would need to be
> converted to Erdas Imagine (HFA) format. The Documentation said that
> the Imagine format is already Tiled. Correct?
Imagine format is inherently tiled, normally with 64x64 blocks.
> 3.) Is the format the same to access an Imagine file as it is to access
> a GeoTiff? I have a sample .map segment that I use to access a GeoTiff:
Yes, Imagine files are accessed the same way in mapserver as GeoTIFF files
are.
> OUTPUTFORMAT
> NAME png
> DRIVER "GD/PNG"
> MIMETYPE "image/png"
> IMAGEMODE RGB
> EXTENSION "png"
> END
I'm not sure why this OUTPUTFORMAT declaration is in your email. It didn't
seem to relate to the text of question 3. But I will say that output formats
is to some degree a distinct issue from input raster formats.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
