alpha transparency and querymap
Jim White
jbw2003 at EARTHLINK.NET
Sun Dec 17 23:16:57 EST 2006
Steve,
Here are the querymap and symbol portions of the mapfile. I think that
is what you mean by type.
SYMBOL
NAME 'hatch-lines'
TYPE HATCH
END
QUERYMAP
STATUS ON
STYLE SELECTED
END
Jim
Steve Lime wrote:
> Jim: What does the querymap def look like? What TYPE are you using?
> Steve
>>>> Jim White <jbw2003 at earthlink.net> 12/13/2006 8:29:28 PM >>>
> Steve,
> First some of the mapfile:
> OUTPUTFORMAT
> NAME mypng
> DRIVER "GD/PNG"
> MIMETYPE "image/png"
> IMAGEMODE rgba
> EXTENSION "png"
> TRANSPARENT ON
> END
> LAYER
> CONNECTIONTYPE postgis
> NAME "counties_q"
> CONNECTION "user=postgres dbname=mydb host=localhost"
> DATA "wkb_geometry FROM county"
> STATUS OFF
> TYPE POLYGON
> TRANSPARENCY alpha
> CLASS
> STYLE
> SYMBOL 'hatch-lines'
> COLOR 255 0 0
> ANGLE 60
> SIZE 10
> END
> STYLE
> WIDTH 2
> OUTLINECOLOR 255 0 0
> END
> TEMPLATE "dummy.html"
> END
> END
> Here's the PHP/mapscript for one of the layers that's used to display
> items the user selects from a select box. The idea is to create a
> transparent hatch pattern over a user created area of interest before
> it
> is submitted. This is currently working with the maps we have but we
> might like to add a satellite background or a shaded dem background,
> which I imagine will look better in true color.
> $this_layer = $map->getLayerByName('counties_q');
> $this_layer->set('status', MS_OFF);
> if (isset($key_counties)) $this_layer->set('status', MS_ON);
> $layer_index = $this_layer->index;
> for($i=0; $i<count($key_counties); $i++){
> @$map->queryByIndex($layer_index,1,$key_counties[$i], MS_TRUE);
> and followed eventually by:
> $queryimage = $map->drawQuery();
> $queryimage->saveImage($maploc);
> The counties_q layer will properly display in rgba mode if I just set
> it
> to default and don't use the queryByIndex method to select particular
> elements in the layer. It will also display properly in 256 color mode
> using queryByIndex. However, when I use queryByIndex in rgba mode the
> hatch pattern is not transparent and has the white background.
> Thanks,
> Jim
Jim White
Biodiversity and Spatial Information Center
North Carolina State University
http://www.basic.ncsu.edu/
