WMS connection error. Failed to draw ...
Sol Lederman
s_lederman at YAHOO.COM
Tue Dec 19 22:30:50 EST 2006
MAPSERVER-USERS Digest - 5 Dec 2006 to 6 Dec 2006 (#2006-339)Dear List Members,
I've been pulling my hair out trying to get MapServer running on a linux box. I once got it working on a different box but this was over a year ago so I may be missing a step or the other box might have been configured differently.
When trying to draw a demo map I get this error:
msDrawMap(): WMS connection error. Failed to draw WMS layer named 'land_fn'. This most likely happened because the remote WMS server returned an invalid image, and XML exception or another unexpected result in response to the GetMap request. Also check and make sure that the layer's connection URL is valid.
The box that I set mapserver up on a year ago can render the same .map file just fine so I don't believe anything in the map file is incorrect.
Below is the map file. I'd appreciate any suggestions on how I can troubleshoot this.
Thanks,
Sol
MAP
EXTENT -125 24 -65 50
SIZE 600 240
NAME WMS-Test_Client
WEB
TEMPLATE mapserver.html
IMAGEPATH "/var/www/cap/docroot/tmp/"
IMAGEURL "/tmp/"
LOG "/tmp/wmsclient.log"
END
LAYER
NAME alert
TYPE point
STATUS DEFAULT
CLASS
COLOR 255 0 0
SYMBOL "alert_symbol"
SIZE 5
LABEL
POSITION UR
SIZE MEDIUM
COLOR 0 0 255
OUTLINECOLOR 255 255 255
END
END
PROJECTION
"init=epsg:4326"
end
FEATURE
POINTS -106.08 35.62 END
POINTS -108.08 47.62 END
POINTS -73.98 40.77 END
END
END
SYMBOL
NAME "alert_symbol"
TYPE ellipse
FILLED true
points 1 1 END
END
PROJECTION
"init=epsg:4326"
END
Layer
Name land_fn
TYPE POLYGON
STATUS DEFAULT
CONNECTIONTYPE WMS
CONNECTION "http://128.117.91.208/viz-bin/wmt.cgi?"
METADATA
"wms_name" "COASTLINES,NATIONAL,STATE"
"wms_onlineresource" "http://128.117.91.208/viz-bin/wmt.cgi?"
"wms_server_version" "1.1.1"
"wms_title" "COASTLINES,NATIONAL,STATE"
"wms_srs" "EPSG:4326"
"wms_formatlist" "image/gif,image/png,image/jpeg"
END
PROJECTION
"init=epsg:4326"
END
CLASS
NAME test
COLOR 0 0 0
END
END
END
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061219/1e45a466/attachment.html
