Projection Issues
Frank Warmerdam warmerdam at POBOX.COM
Mon Feb 6 08:15:25 EST 2006
On 2/6/06, Neil Saunders <n.j.saunders at gmail.com> wrote:
> I'd like to set the projection to a mercator WGS84.
> All I have is a simple mapfile with the map projection set to :
> PROJECTION
>    "proj=merc"
>    "ellps=WGS84"
> END
Neil,
The above is fine, but by default MapServer will assume your
input layer is the same projection and do nothing with it.
You need to add the following declaration for the LAYER:
  PROJECTION
    "+proj=latlong +datum=WGS84"
  END
MapServer does not normally pull the layer coordinate
system from the datasource.
Best regards,
