Crash with query
Fernando Simon
fsimon at UNIVALI.BR
Mon Feb 13 11:35:22 EST 2006
Hi Jelmer,
How did you define your data definition for your layer? What method
of query are you using?
Best regards.
Fernando Simon
Mapserver and Oracle Spatial developer
G10 - Laboratorio de Computacao Aplicada - Brazil
http://www.univali.br/g10 - UNIVALI/CTTMAR
Jelmer Baas wrote:
> Dear all,
> Once again, I have a problem. I finally stopped using the .tab files
> and switched to the "live" Oracle data. Everything goes well, until I
> run a query (to find out what's underneath my mousepointer).
> My Query:
> http://loopplank/coconjb/scripts/mapserv.exe?mode=nquery&map=../query.map&imgext=189991.7+443456.5375+191827.6+444833.4625&imgxy=339+209&imgbox=329+199+349+219&layers=netherlands+TABCAB
> The query.map file is brand new, specially made this query (to test),
> my symbol set is also OK. It's really when I switch from .tab files to
> Oracle that it does wrong. And yes, MapServer *does* display the lines
> properly (i.e., no crash with same .map & .sym files).
> How can I find out how, where and why this goes wrong? I only get a
> "The instruction at <some address> referenced memory at <some
> address>. The memory could not be "read"."
> I'll try to install a debugger, though I doubt that would do anyone
> any good. Running "Hobu's kitchen sink MapServer 4.6" binaries on WinXP.
