Mapserver crashes while antialiasing
Steve Lime
steve.lime at DNR.STATE.MN.US
Tue Feb 14 10:54:18 EST 2006
Torsten: I'm pretty sure this is a problem with GD. Look for a general announcement
to the list on the topic in a few minutes...
Steve
>>> Torsten Weber <TWeber at TRAFFIC-CONSULT.DE> 02/14/06 8:25 AM >>>
Hi Umberto,
thanks for your advice.
I've configured the apache on the SuSE 9.2 System to use php as a fastcgi prog
instead of the module. After solving some problems passing the oracle
environment to the cgi, I got the the same result as working with the moduled
version with the little difference that the php prog is now crashing.
I get the following error from the apache server every time I use the RGB
mode:
"Server error!
The server encountered an internal error and was unable to complete your
request. Either the server is overloaded or there was an error in a CGI
script."
8 Bit works fine but slow??.
Do you have some other ideas?
Regards
Torsten
Am Dienstag, 14. Februar 2006 10:17 schrieb Umberto Nicoletti:
> perhaps you are using php as a shared module?
> Note that php as a shared module is not supported and will quite
> likely cause crashes like those you are experiencing.
> Reagrds,
> Umberto
> On 2/14/06, Torsten Weber <TWeber at traffic-consult.de> wrote:
> > Hi all,
> > I'm using mapserver 4.6.2 and 4.8.1 on SuSE 9.2 and 10.0 with
> > php_mapscript. I've compiled both mapservers on both machines for using
> > oracle to get the spatial information. If I use 8Bit coloring all things
> > work fine (but no antialiasing). Within RGB mode the server gets
> > segmentation faults. But sometimes it works one or two times (don't know
> > why).
> > Versions:
> > mapserver: 4.6.2 + 4.8.1
> > SuSE Linux: 9.2 + 10.0
> > php: 4.3.8 + 4.4.0
> > oracle instantclient 10g
> > apache: 2.0.50 + 2.0.54
> > gd: 2.0.28 + 2.0.32
> > I'm using antialiasing on line and polygon Layers only. But there are
> > raster layers also.
> > Here is an example for both antialiased layers:
> > Polygon Layer using data from shape files.
> > LAYER
> > NAME "Gemeinden"
> > PROJECTION
> > "init=epsg:31467"
> > END
> > METADATA
> > "DESCRIPTION" "Gemeinden"
> > "RESULT_FIELDS" "Name"
> > "RESULT_HEADERS" "Name"
> > "SELECTABLE" "false"
> > END
> > DATA "/srv/www/htdocs/geodata/Admin_Grenzen/Gemeinden"
> > TYPE POLYGON
> > TRANSPARENCY 50
> > CLASS
> > NAME "Gemeinden"
> > TEMPLATE "void"
> > STYLE
> > COLOR 180 180 0
> > OUTLINECOLOR 90 90 0
> > SIZE 3
> > ANTIALIAS TRUE
> > END
> > END
> > END # Layer
> > Line Layer using oracle spatial data.
> > LAYER
> > NAME "kanten"
> > PROJECTION
> > "init=epsg:31467"
> > END
> > DEBUG ON
> > CONNECTION "user/pass at oradb"
> > CONNECTIONTYPE oraclespatial
> > DATA "GEOLOC FROM (SELECT GEOLOC, ID, BEZEICHNUNG, ART,
> > TYP FROM STRECKEVIEW) USING UNIQUE ID"
> > TYPE LINE
> > SYMBOLSCALE 20000.0
> > METADATA
> > "DESCRIPTION" "Straßen"
> > "RESULT_FIELDS" "ID,BEZEICHNUNG,ART"
> > "RESULT_HEADERS" "Nummer,Name,Typ"
> > "SELECTABLE" "true"
> > "LAYERDESC" "Straßen"
> > END # Metadata
> > CLASS
> > NAME "Autobahnen"
> > TEMPLATE "void"
> > EXPRESSION ([TYP]=21)
> > STYLE
> > SYMBOL "lstandard"
> > COLOR 0 0 200
> > SIZE 7
> > ANTIALIAS TRUE
> > MINSIZE 7
> > MAXSIZE 18
> > END
> > STYLE
> > SYMBOL "lstandard"
> > COLOR 255 255 255
> > SIZE 4
> > ANTIALIAS TRUE
> > MINSIZE 4
> > MAXSIZE 12
> > END
> > STYLE
> > SYMBOL "lstandard"
> > COLOR 0 0 200
> > SIZE 2
> > MINSIZE 2
> > MAXSIZE 5
> > ANTIALIAS TRUE
> > END
> > LABEL
> > ANGLE AUTO
> > COLOR 256 0 0
> > POSITION AUTO
> > SIZE LARGE
> > TYPE truetype
> > FONT "verdana"
> > END #LABEL
> > END # Class
> > CLASS
> > NAME "Bundesstraßen"
> > TEMPLATE "void"
> > EXPRESSION ([TYP]=22)
> > #MAXSCALE 250000.0
> > STYLE
> > SYMBOL "lstandard"
> > COLOR 50 50 50
> > SIZE 5
> > MINSIZE 5
> > MAXSIZE 15
> > ANTIALIAS TRUE
> > END
> > STYLE
> > SYMBOL "lstandard"
> > COLOR 255 255 0
> > SIZE 2
> > MINSIZE 2
> > MAXSIZE 10
> > ANTIALIAS TRUE
> > END
> > END # Class
> > CLASS
> > NAME "Landesstraßen"
> > TEMPLATE "void"
> > EXPRESSION ([TYP]=23)
> > MAXSCALE 250000.0
> > STYLE
> > SYMBOL "lstandard"
> > COLOR 50 50 50
> > SIZE 5
> > MINSIZE 5
> > MAXSIZE 15
> > ANTIALIAS TRUE
> > END
> > STYLE
> > SYMBOL "lstandard"
> > COLOR 250 250 250
> > SIZE 2
> > MINSIZE 2
> > MAXSIZE 10
> > ANTIALIAS TRUE
> > END
> > END # Class
> > CLASS
> > NAME "Kreisstraßen"
> > TEMPLATE "void"
> > EXPRESSION ([TYP]=24)
> > MAXSCALE 75000.0
> > STYLE
> > SYMBOL "lstandard"
> > COLOR 50 50 50
> > SIZE 3
> > MINSIZE 3
> > MAXSIZE 10
> > ANTIALIAS TRUE
> > END
> > STYLE
> > SYMBOL "lstandard"
> > COLOR 250 250 250
> > SIZE 1
> > MINSIZE 1
> > MAXSIZE 6
> > ANTIALIAS TRUE
> > END
> > END # Class
> > CLASS
> > NAME "Sonstige"
> > TEMPLATE "void"
> > EXPRESSION ([TYP]<21 OR [TYP]>24)
> > MAXSCALE 50000.0
> > STYLE
> > SYMBOL "lstandard"
> > COLOR 100 100 100
> > SIZE 1
> > #ANTIALIAS
> > MINSIZE 1
> > MAXSIZE 10
> > ANTIALIAS TRUE
> > END
> > END # Class
> > END # Layer
> > Used outputformat:
> > OUTPUTFORMAT
> > NAME pngrgb
> > DRIVER "GD/PNG"
> > MIMETYPE "image/png"
> > IMAGEMODE RGB
> > FORMATOPTION INTERLACE=OFF
> > TRANSPARENT OFF
> > END
> > It doesn't matter if I use GIF or jpeg instead.
> > Is anyone out there, who could help me?
> > Many thanks and best regards
> > Torsten
T. Weber E-Mail: TWeber at traffic-consult.de, TWeber at weber-sys.de
Traffic Consult GmbH Herzbachweg 65 63571 Gelnhausen
Tel: 06051 / 82889-15 Mobile: 0179 / 5340731 Fax: 06051 / 82889-29
E-mail: info at traffic-consult.de WWW: http://www.traffic-consult.de
