Polar reprojection (again)
Ed McNierney
ed at TOPOZONE.COM
Thu Feb 16 16:06:55 EST 2006
What is the file format and geographic extent of the raster image you're
trying to reproject? Raster data in "lat/lon" projection (EPSG:4326) in
polar regions is rather badly distorted if not undefined or infinite in
extent.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Christopher Condit
Sent: Thursday, February 16, 2006 3:44 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Polar reprojection (again)
All my data is epsg:4326
Each layer has:
PROJECTION
"init=epsg:4326"
END
I want proj.4 to re-project this on the fly to a polar view, but it only
works for vector data.
>What does the PROJECTION of your RASTER LAYER look like? It needs to
match
>whatever PROJECTION your raster data is in.
>MAP
> PROJECTION
> "proj=laea"
> "lat_0=-90"
> END
> LAYER
> TYPE RASTER
> PROJECTION
> END
> END
>END
Behalf Of Charlton Purvis
Sent: Thursday, February 16, 2006 12:18 PM
> Under certain application conditions, I need to re-project the map
into a
> polar view. To do this I change projection string to
> PROJECTION
> "proj=laea"
> "lat_0=-90"
> END
> This works very well for all of my vector data, but none of my raster
data
> appears. The raster data is in AAI/Grid format. Will this raster
format
> not re-project? Should I use a different projection string?
