Polar reprojection (again)
Frank Warmerdam
warmerdam at POBOX.COM
Thu Feb 16 16:09:03 EST 2006
Christopher Condit wrote:
> I asked about this a while ago – but got nothing. I’m trying again…
> Anyone know about this??
> I’ve got a mapfile that draws perfectly in epsg:4326 – with both raster
> and vector data (also in epsg:4326).
> Under certain application conditions, I need to re-project the map into
> a polar view. To do this I change projection string to
> PROJECTION
> "proj=laea"
> "lat_0=-90"
> END
> This works very well for all of my vector data, but none of my raster
> data appears. The raster data is in AAI/Grid format. Will this raster
> format not re-project? Should I use a different projection string?
Chris,
The problem isn't the projection string or the specific raster file format.
It presumably relates to messy issues with polar reprojection and raster i
general. Can you bundle up a sample map and data that I can use to
reproduce your problem? I may be able to provide advice or fix things up
a bit.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
