Mapscript Csharp dll
Shaik A. Hussain shussain at ATSINCORP.COM
Thu Feb 16 17:49:44 EST 2006
Hi All,
I am using Mapscript Csharp dll and drawmap.cs script from Mapserver
Howard Butler's kitchen sink binaries. I am getting the following error
when I use the drawmap.exe through command line.
C:\temp\dotnet\MapserverTest\bin\Debug>drawmap  postgis.map pg.png
# Map layers 1; Map name = EARS
Layer [0] name: countyp020
Unhandled Exception: System.NullReferenceException: Object reference not
set to
an instance of an object.
   at mapscriptPINVOKE.mapObj_draw(HandleRef jarg1)
   at mapObj.draw()
   at DrawMap.Main(String[] args) in
c:\temp\dotnet\mapservertest\drawmap.cs:lin
e 63
Does any one can help me how to fix this error.
Here is the map file I am using
NAME EARS
SIZE 90 52
STATUS ON
EXTENT -125.285 25.560 -66.536 52.656
UNITS meters
SYMBOLSET  "C:\Symbols\symbols.sym"
FONTSET  "C:\Symbols\fonts.list"
IMAGECOLOR 240 228 190
TRANSPARENT OFF
LAYER
  NAME "countyp020"
  TYPE Polygon
  STATUS default
  CONNECTION "user=postgres password=pwd dbname=PAMS host=localhost
port=5432"
  CONNECTIONTYPE postgis
  DATA 'countyp020'
  CLASS
    OUTLINECOLOR 190 190 190
    SYMBOL 'circle'
    SIZE 1
  END  # CLASS
END  # LAYER
END  # MAPFILE
Thanks,
Anwar
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060216/7699d79a/attachment.html
