Failed connect to Oracle DB
Marc Jacquin
marc.jacquin at MAGELLIUM.FR
Mon Feb 20 05:57:50 EST 2006
The DATA tag should be DATA "Geometry FROM MyTable using srid 1000005"
instead of DATA "Geometry FROM MyTable using srid = 1000005" (Remove
"="). Also make sure that the Oracle geometry type is what you expect.
You may also add some debug or log by defining the MS_ERRORFILE environment
variable (e.g. c:/temp/mserror.txt) and check for Oracle errors in it.
Where did you get the compiled version for C#?
Marc
-----Message d'origine-----
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la
part de NBolbot (sent by Nabble.com)
Envoyé : lundi 20 février 2006 10:32
À : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : [UMN_MAPSERVER-USERS] Failed connect to Oracle DB
Hello everybody,
I have my problems to get data from Oracle Database.
I use compilied version of mapserver for C#. There is no problems to draw a
picture using test-shapefiles. But when I trying to draw data from Oracle
Database I get an empty picture without any error message.
I use following map-file:
NAME DEMO
STATUS ON
SIZE 400 400
EXTENT 1 1 200 200
UNITS METERS
IMAGETYPE GIF
IMAGECOLOR 255 255 255
# Start of web interface definition
WEB
MINSCALE 1
MAXSCALE 100
# On Windows systems, /tmp and /tmp/ms_tmp/ should be created at the root
# of the drive where the .MAP file resides.
IMAGEPATH "/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
LOG "/tmp/ms_tmp/gmap.log"
END
# Start of layer definitions
LAYER
NAME test
TYPE LINE
CONNECTIONTYPE oraclespatial
CONNECTION "myuser/test at test"
CLASS
STYLE
OUTLINECOLOR 0 0 0
COLOR 255 0 255
END
END
END
END # Map File
What configuration should I make to work with Oracle Database?
View this message in context:
http://www.nabble.com/Failed-connect-to-Oracle-DB-t1154157.html#a3027692
Sent from the Mapserver - User forum at Nabble.com.
