Fatal error: [MapServer Error]: msSDELayerGetShape():
ruth schÿfffff6nbuchner ruthschoenbuchner at YAHOO.DE
Wed Feb 22 07:47:40 EST 2006
Dear people,
  I have got a problem querying a layer with ArcSDE and a created
pointobj();
  In my mapfile I definded the correct parameters for the
ArcSDE-Connection because I can display the layers without any problems.
  When I want to query a layer, it says:
SE_stream_fetch_row(): Invalid pointer argument to function. (-65)   in
/../../webgis.php on line 142
  Line 142 of my webgis.php says the following:
  $Shape = $Abfragelayer->getShape($ti,$si);
  bevor line 142 I defined the queryable layer and the results:
  //create point object and querybypoint
  $punkt=ms_newPointObj();
  $punkt ->setXY($x_real,$y_real);
  @$map ->queryByPoint($punkt, MS_SINGLE, -1);
  //test, if query was succesful
  if((@$map ->queryByPoint($punkt, MS_SINGLE, -1))==MS_SUCCESS){
  $Abfrage="Abfrage hat geklappt";
  //find queryable layer
  for($iLayer=0; $iLayer < $map->numlayers; $iLayer++)
          $Abfragelayer = $map->GetLayer($iLayer);
          $numResults = $Abfragelayer ->getNumResults();
          if ($numResults == 0)
              continue;
  //open table of queryable layer and read row
  $Abfragelayer->open();
  $Spalte=explode(" ",$Abfragelayer->getMetaData("RESULT_FIELDS"));
  //read entry of row
  //define specific object of shape
  $resultat=$Abfragelayer->getResult(0);
   $si=$resultat->shapeindex;
   $ti=$resultat->tileindex;
   $ci=$resultat->classindex;
  Surely I made something wrong with correct options and  parameters
regarding to ArcSDE in my php-script, because I am newbie to  MapScript
  Can anybody help? Regards, Ruth
Telefonieren Sie ohne weitere Kosten mit Ihren Freunden von PC zu PC!
Jetzt Yahoo! Messenger installieren!
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060222/d4820248/attachment.html
