Problem with WMS Connection
Ed McNierney
ed at TOPOZONE.COM
Fri Feb 24 11:37:38 EST 2006
Dennis -
Thanks - the server seems fine. But you're not defining a PROJECTION
block for the WMS layer - you need to tell MapServer that the input
image is in EPSG:4269 projection rather than in the default LCC
projection of your output image. Without that, MapServer will treat it
as LCC input coordinates, and the resulting image will be way off-screen
somewhere.
I might be wrong on that - I got in the habit of specifying PROJECTION
blocks for WMS layers a long time ago, when they were required. That
might have changed, but it's worth a try.
- Ed
P.S.
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
From: Dennis Megarry [mailto:dennis at megarry.com]
Sent: Friday, February 24, 2006 11:01 AM
To: Ed McNierney
Subject: RE: [UMN_MAPSERVER-USERS] Problem with WMS Connection
I do get a response from it... The actual MAP file is below (since this
is sent off-list). I tried your suggestion and put "&" on the end (see
below) and still nothing.. ARGH!
[MAP file contents removed by Ed before replying on-list]
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060224/6db7b701/attachment.html
